WTB SDCE 8 Rib or ATI 8 Rib for LS1
Location: Virginia - Where Rednecks and Presidents Come From
Mainly looking for the SDCE "Stock-Fit" 8-rib Crank Pulley for my LS1 F-Body, but will consider buying your complete SDCE bracket setup if necessary.
Would also be interested in the ATI Damper / Procharger 8 Rib Pulley setup for LS1.
LMK what you have...
Thanks in advance!
Thanks in advance!
i have an sdce setup , and it has a hub of some sorts that was supposed to fit a stock balancer but it was an older setup . i can take a pic of it . not sure how it works .
I'm still in the market for this part, guys!
Again, I'm looking for the SDCE 8-rib crank pulley that fits into the LS1's stock balancer.
Or, if you have one made by another company that I'm not aware of, I'm up for options. As long as it's an 8-rib blower pulley that fits DIRECTLY into the stock balancer. I don't want to have to buy an ATI balancer just to go 8-rib.
What does your setup look like? I built my own system but using the ATI balancer and procharger 7.65 crank pulley. My setup also uses a true 8 rib tensioner pulley. Only catch is I have a ls2 water pump like the aster bracket uses.
