Anybody know about air compressors?
I picked up an older craftsman 60 gal compressor model# 919-176500 and for one Im not sure how to hook it up to power. It has a red a black and green wire so im assuming its a 120v unit. Anyway, I hooked it up temporarily to an outlet just to see if it would turn on.
It ran for a few and then it started to slow down till it finally clicked and stopped turning. It built press up to about 15 psi. After that, I turned it off and turned it back on and it runs but very slow until it eventually just stops again. Any ideas? I think its a weak motor..
red black green ? sounds like 220 ?
im not %100
But usually 110v is white, black and green.
Sounds like you have to buy a plug and make your own end.
Should say the voltage necc on the electric motor
im not %100
