6.0 6262TT oil pressure issue?
Hey guys, we were seeing ~15psi oil pressure at idle and no more than 30 or so while driving. That was on VR1 10-30. I called the machine shop and they said they left the main bearing clearances a little looser, due to my horsepower estimates (1K flywheel).
So we switched to Brad Penn 20w50 and now I have 20psi at warm idle, and up to 40-45 while driving. Is that enough?
I'm thinking I should get a melling high-volume pump, but also read they suck the stock pan dry.
Advice??
Advice??
If more psi is wanted why not just shim the oil pump spring alil? I shimmed a new stock 5.3 gm pump and have 40-50psi at idle 75-80psi wot, cruise with 65ish psi..i fed the s480 with a unrestricted 4an and returned with a 10an..switching to twins for this coming season and if i dont have the psi i wanted ill shim pump spring till i do.
Dang. im sure yours will be fine with a heavy oil. i have hell getting my oil temp up so psi is always pretty high.lake water cooling the block with a 8qt pan makes it tuff to build oil temp prior to a pass.when i race this spring i wont be able to start my engine until im about to leave the rope
Advice??
Advice??
Maybe. Depends on your bearing tolerances I guess. Mine are looser than stock for sure. I'm more than likely going to do a HV pump just for peace of mind...just wanted advice on which one and whether anyone runs them successfully with a stock pan.
Anyway, I'll just grab a 10296 and give it a try. Thanks!
Formerly 4mulaJoe
I see 15psi hot at idle. Goes up with rpm to close to 50psi IIRC at the shift point. Maybe 1500 miles on it but a I'd guess 200-300 pulls. Had a long conversation with the builder about it, and he convinced me it wasn't a problem. You are moving the same volume of oil that that pump always moved. I don't think you are seeing a scenario where the bearings aren't lubricated, which is what matters. Runnin castrol 20w50 and changing it probably more often than necessary.
