Twin 76mm on 5.3
Old 12-19-2013, 06:19 PM
Wes Hardin's Avatar
Default Twin 76mm on 5.3
Need help. I have a chance to buy 2 76 mm turbos (Percision)at a good price. Will a 5.3 with a cam spool them.
Are they to much
Old 12-19-2013, 07:52 PM
Gordon0652's Avatar
I'm sure the 5.3 will but when is what I am questioning. Why not use one? You'll make 800.
Old 12-19-2013, 07:56 PM
MikeFSKSpeed's Avatar
Go with a single and have a backup ready!
Old 12-19-2013, 10:01 PM
Wes Hardin's Avatar
Thanks. I have been torn between a single or twin. I am looking for a 1000hp at the wheels. I talked to a buddy and he said 2 bw s366. I'm lost in this as its my first ls and first turbo. I'm a old school bbc with the gas. Want to buy once not 3 or4. Thanks guys
Old 12-19-2013, 10:58 PM
mrstepheneades's Avatar
Put em both on there and be a good roll race car lol. Really need more cubes to spool them good. I'd run one and pin the wastegate and just see what you can make with one. My 75mm borg is making over 800 on my stock ls1 with cam. And not even maxed out. Maybe could see 900rwhp with a single precision like you have on a 5.3. I don't know how the precision compare to Borg on power comparability.
Old 12-20-2013, 09:37 AM
1fast bird's Avatar
Are they the 7675 precisions? Twin 76's would be way too much turbo for those cubes in my opinion. Like said above, just run a single and have a backup. Or search for twin 60's.....
Old 12-20-2013, 09:40 AM
Twin turbo c5's Avatar
Just buy one . You'll never spool 2 unless you spray it on the boost. One 76mm will make plenty of power for ya.
Old 12-20-2013, 11:29 AM
DBRODS's Avatar
Yep a 5.3 will never spool twin 76s.
Old 12-20-2013, 11:45 AM
DBRODS seems like yours has no problem lol.
Old 12-20-2013, 12:47 PM
Heavy H.P.'s Avatar
Can I get some more info on your build?
Old 12-20-2013, 01:46 PM
3pedals's Avatar
need to know the turbine size and a/r ratio , and cam specs to even guess whether the 5.3 will be able to spool them both
Old 12-20-2013, 02:40 PM
I'm betting there 96ar exhaust side . Every precision 76 I've seen and had a96 or bigger.
Old 12-20-2013, 02:50 PM
DBRODS's Avatar
Mine are Tseries Billet 7668s with .81AR housings.
Old 12-20-2013, 02:53 PM
That's alot better but your still gonna have spooling problems in my opinion.
Old 12-20-2013, 03:20 PM
Link to thread in sig. Cell phone post like above doesn't post the sig.
Old 12-20-2013, 04:44 PM
1fast bird's Avatar
I never said they wouldn't spool. It would just be more turbo than you would ever use with a 5.3.....
Old 12-20-2013, 06:14 PM
Forcefed86's Avatar
http://www.youtube.com/watch?v=5M3wJfB4mAI
Sounds like some healthy rpm too when those things are spooling. How big is the converter? I agree it's too much turbo for a 5.3. Buddys 370 was going low 8's on twin 63's.
Old 12-22-2013, 12:10 PM
11_silverado_noob's Avatar
I have two NEW! Precision 6176E MFS Turbos. These have never been run and are brand new. They are 61/76e .68ar vband hook up t4 flange. I am looking to get $1200 for both shipped. Perfect for a 5.3.
Old 12-22-2013, 02:21 PM
DBRODS's Avatar
When it was stock I spun it to 7200. That was a Ptc 9.5 that would stall to 4400 then flash to 6000 in a 80E. Its built now and been pushed it to 32psi. converter makes or breaks a auto setup as far as spooling.
Old 12-23-2013, 03:57 PM
IT_SS's Avatar
well **** I guess I can run twin 78s on my 370 then
Quick Reply: Twin 76mm on 5.3
