Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
still wheel hop after cradle, trailing are, and dif bushing
Old 12-23-2013, 10:34 PM
rbsurfer's Avatar
Default still wheel hop after cradle, trailing are, and dif bushing
As title states I got the 95 cradle diff and trailing arm from Revshift and still hop ??? My other v didn't hop with only a Bmr kit?? I'm so confused about this my other v was a 05 this is an 06 is there something I'm missing my tires are hankook ventus v12
Old 12-23-2013, 10:59 PM
itsslow98's Avatar
I had an anti hop axle on my 05 and it would still hop. Some guys can do butter smooth burnouts in stock form and some cars seem to suffer way worse. I sold my car because of it in all honesty. I wish I had some more insight for you but even when I had mine no one had a solid answer except to drop the coin on an 8.8.
Old 12-23-2013, 11:03 PM
Onefast V's Avatar
Gforce axles
Old 12-23-2013, 11:58 PM
Sweetwilliebrownjr's Avatar
I had gforce axles. Still hopped. I installed trailing arm bushings, control arm bushings, and cradle bushings. Hopped less, but still hopped. I installed the cs 8.8 kit. The hop is gone except in very wet conditions. Wheel hop is a result of poor traction. Different things on different cars attribute to poor traction. It's trial and error, and comes at a cost. Monetary, mental, physical, and of course there's the extra noises you get. Drag radials will prolly alleviate the hop, but chit starts to break. I always hear about burnouts, and don't hear much about traction. Makes me wonder what folks really want out of these cars. Back off of the throttle, and you'll get down the road.
Old 12-24-2013, 12:30 AM
rbsurfer's Avatar
Well I was thinking traction but I feel like I'm not solving it in covering it.. on a side note I am on h&r springs and have a little camber but I guess I'll go grab a set of radials again
Old 12-24-2013, 06:25 AM
DMM
DMM's Avatar
Get some better tires. Stickier tires will help with the hop.
Old 12-24-2013, 07:41 AM
silver1r's Avatar
I agree it has alot to do with the tires. I am on h&r springs, have all 95 bushings in the rear and the cs 8.8. Unless I dump the clutch in 2nd gear, I get wheel hop like crazy. Others with the same mods claim they can't get wheel hop if they tried. The only thing I didn't have in common with them in a thread I posted a while back, was tires, and tire sizes. I am running 245 nitto invos, and the guys with little to no hop were running 275's. I will know next summer when I switch to 275's
Old 12-24-2013, 07:56 AM
punishmentcycle's Avatar
i had alot of hop after the 8.8 swap... my somewhat of a fix was having the car alighned again..now i only get hop in the rain or slow roll stabs
Old 12-24-2013, 09:29 AM
Fuzzy_Wuzzy's Avatar
From reading the forums for several years it seems like every car is just a little different. I know i ran the DSS axles and it worked great, nice smooth burnouts. Then I decided i wanted to try the geforce axles, I could have sworn they shipped me stock axles, it hops so much... Yet others the geforce axles work great... there are just a lot of variables.
I am hoping that once i install my cradle bushings it helps some more too.
Old 12-24-2013, 09:35 AM
rbsurfer's Avatar
CAN WE ADJUST CAMBER IN THE REAR STOCK? or do I need to buy camber adjustment arms
Old 12-24-2013, 04:40 PM
bmylez's Avatar
You can adjust camber, but since you are on H&R springs, you will max out the stock arms. I'm on H&R springs as well and I'm still at -3* with the arms maxed out, so you'll need aftermarket.
Old 12-24-2013, 11:04 PM
rbsurfer's Avatar
What aftermarket arms should I buy?
Old 12-25-2013, 12:00 AM
There are none... -3 camber is quite a bit though. you might have to oval out some holes
Quick Reply: still wheel hop after cradle, trailing are, and dif bushing
