pro built automatics 4L80E rebuild kit
formerly twolow02fransen (2014-1-2)
Category: Drivetrain
Price: $900876564
Part Fits: 93-02 Chevrolet Camaro
Location (State): MA
Item Condition: Brand New
Engine: LS1/LS6
LS Engine?: Fits LS Engine
the kit is complete minus the HD-2 shift kit i used for my other 4L80E that I'm using in my truck
heres a parts list of what comes with the kit
SOLD!!!
4L80E Rebuild Kit Street/Strip 1996 Complete description of parts in the rebuild kit.
4 Borg-Warner Overdrive clutches .080
4 Overdrive "low drag" Turbulator steels .099
3 Borg-Warner Overrun clutches .080
3 Overrun "low drag" Turbulator steels .099
5 Borg-Warner Forward clutches .080
5 Forward steels .077
1 Forward steel, waved .060
5 Borg Warner Hi-Energy Direct clutches .080
5 Kolene Direct steels .090
4 Borg Warner Hi-Energy Intermediate clutches .071
4 Kolene Intermediate steels .076
Heavy Duty intermediate snap ring that installs in the case to prevent the case lugs from breaking out.
Borg Warner Hi-Energy Intermediate band
Borg-Warner 34 element Intermediate sprag
Borg Warner rear roller clutch
Borg-Warner Rear band
Borg Warner Overdrive Roller sprag (.309" OD Rollers)
Bonded rubber overrun piston
Bushing kit
Sealing ring kit, Peek "step cut" stator & center support rings Viton & cast iron accumulator rings
Thrust washer kit
Oem Sealed Power filter
Paper & rubber (gasket kit) w/front & rear seal
Torrington bearing kit (Heavy Duty)
Center support seals, (eliminates case to center support leaks)
TransGo Predrilled separator plate
TransGo 4L80E-HD2 Street/Strip Shift kit. Comes with wide boost valve, pressure relief valve. Reduces parts breakage from high line pressure & 3rd clutch failure. Prevents codes 68, 39, 45, no lockup & no overdrive. Triples 3rd gear holding power.
Details
Part Number SSRK4L801996
Price: $576.77
Options
