Setting base fuel pressure w/ boost FPR
Old 01-15-2014, 11:02 AM
Burken01's Avatar
Getting ready to start my engine this week, I have a magnafuel boost referenced FPR
I want to set it at 58 psi
So I pull the boost line off of the FPR and plug the line end, leave the port on the FPR uncovered?
Start the car and adjust the screw until I reach 58 psi, I have an electric fuel pressure gauge to monitor it..
How's that sound? Any extra tips?
Thanks
It's a dual walbro setup w/ second one on a 1 psi Hobbs switch
Old 01-15-2014, 11:13 AM
forcd ind's Avatar
I set mine with the engine off, pump on-once you fire it up, the vac. will pull down the FP a little, at WOT it will be back what you set it at, plus whatever the boost raises it to
you can set it running with the line off if you want, ck it against non running and see if the pres is the same
Old 01-15-2014, 11:15 AM
Burken01's Avatar
How do you set it when it's not running
Old 01-15-2014, 11:26 AM
dschmittie1's Avatar
either use HPT to command the pump or jumper the relay to make it run
Old 01-15-2014, 11:28 AM
Burken01's Avatar
Ok, do I need both pumps running when setting fuel pressure.. Or will one be fine..?
Old 01-15-2014, 11:29 AM
fotoboy's Avatar
How is your second pump setup to come on?
Old 01-15-2014, 11:38 AM
Burken01's Avatar
1 psi Hobbs switch..
Old 01-15-2014, 12:07 PM
RonSSNova's Avatar
Since base FP is what you will be driving around on, and you wont have the second pump on until boost, I would think you set base with the first pump.
Would be interesting though to see if the second pump adds pressure. Even if it does, you will account for that in the tune.
Old 01-15-2014, 12:16 PM
If turning on the second pump adds pressure then your return line is too small or restricted
setting up base pressure with 1 pump is fine
Old 01-15-2014, 12:40 PM
stevieturbo's Avatar
Thanks
The method you have suggested is the easiest and best method. Although I prefer a mechanical gauge for their simplicity.
Old 01-15-2014, 12:45 PM
Burken01's Avatar
Yes I'll set it with the engine off to get it "close" then start it up and tweak it a hair..
Old 01-15-2014, 03:28 PM
RonSSNova's Avatar
Agree. I think folks discount the size of the return line. It has to flow all the fuel at low engine output. Any pressure built in it will skew the true base pressure.
Quick Reply: Setting base fuel pressure w/ boost FPR
