help with finding belt squeek
I recently had a belt squeak took off the serpentine belt and spun them all the tensioner was shot so I replaced the tensioner pulley and new belt and every thing was quiet for 2 days. Now the same squeak is back and I can't seem to find it any ideas on what it is guys it is a ls2
Long shot but check your ac belt too.
I had a nasty squeal that wouldn't go away. Replacing tensioner didn't fix it.
Looked closer and noticed the ac belt had been thrown off and was rubbing the balancer. Then I noticed the serpentine riding the edge of the balancer, so I shut it off and pulled it off. It was split. I then found the crank bolt to be loose, balancer had walked about 1/8 inch.
I'd heard this squealing for 3 days but just powered through it. Glad I didn't throw the balancer lol
Coolant can also make a brand new belt squeak. :
I checked the PS pump all good. All pulleys spin smooth removed AC belt and its Quiet for now but I will know for sure in the morning the belt looked like a belt with 60k miles on it nothing terrible at all
Mine has a similar squeak, does it when its damp or cold out. Goes away after 10 minutes of driving or like you say warming up. Not sure what it is...I never hear it during the summer. Someone on the forum here recorded the exact problem and posted the video within the past year. Not sure if it got resolved.
Found it
https://www.youtube.com/watch?v=1Y4J...=youtu.be&hd=1
Thread with no resolution.
https://ls1tech.com/forums/cadillac-...ory-video.html
Found it
Well I replaced the tensioner pulley And came back.. just slapped a new idler pulley on.. the old idler was a little pitted and the grease was black and nasty. I put in the refrigerator let it get down to cool temp and spun it slowly and it was a little bumpy / rough and I mean a little so I'll see if that did it I'll know tonight cause its gonna be cold and moist
So got it to squeak for like 5 mins and its gone but I'm prob jinx in myself and next time I drive it will squeal like a pig in heat but as of now it was the idler pulley
Still squeaking took off the AC belt still squeak. Took off serp belt and put on just AC belt squeak is there I'm so lost with this. I've tried gates dayco and gatorback . It seems to only not squeak with the stock belt made by mitsuboshi
My brothers was doing the same two weeks ago. Turned out it was the harmonic balancer, put a brand new serpentine belt and it stopped for two days. We finally got the harmonic balancer changed and its been a week and everything seems fine now.
The balancer is what I was thinking cause its the only common pulley between both belts so IMA try to get an ati just gotta get some cash doesn't help I just bought a clutch. Ss brake lines, pads, rotors , and Hurst shifter and tires lol
