The Driveshaft Shop 3.5" Aluminum DS?
Old 01-20-2014, 02:17 PM
Super Hulk Smash
JakeFusion's Avatar
Default The Driveshaft Shop 3.5" Aluminum DS?
Anybody used DSS Driveshafts? I've talked to Frank and was impressed with the operation there. I'm thinking of going with a 3.5" Aluminum shaft setup for my 10-bolt with a 1350 U-Joint and adaptor, so I can run it now in my 10-bolt and then when it explodes, I can remove the adpator and run it as is in a 12-bolt or return to Frank and have it shortened for a 9" or S60.
I just want to make sure the rearend blows up and not the driveshaft. I have an expensive trans and exhaust (and not to mention me) that I'd like to keep scratch free. I am running a BMR DS Loop and it's nearly 4.5" wide at its narrowest, so I think it will work.
Old 01-22-2014, 12:55 PM
Super Hulk Smash
JakeFusion's Avatar
Okay, well I placed my order. I'll see how it does.
Old 01-22-2014, 04:57 PM
BrntWS6's Avatar
I had never head of them. I think most go with the PST which is what I have in a 3.5" aluminum and it did fit my BMR loop easily before I switched over to the MWC one.
Old 01-22-2014, 06:59 PM
Super Hulk Smash
JakeFusion's Avatar
They do a lot of work with Vettes, Gen V, and CTS-V. But they make aluminum and carbon fiber driveshafts.
Old 07-03-2014, 07:57 AM
SmokedOutZ28's Avatar
Did you get your driveshaft, How do you like it? I am also looking at the 3.5'' aluminum one.
Old 07-03-2014, 08:05 AM
Super Hulk Smash
JakeFusion's Avatar
I like it so far.
Old 07-09-2014, 11:55 AM
Driveshaft Shop's Avatar
We also do high speed balancing on our shafts
new pulse welding system also.
Old 07-18-2014, 09:12 AM
CGCBandit's Avatar
Just a shout out to Frank, I beat the pi$$ out of my 8.8irs gto conversion from them, nothing but the best imo. Just realized you had 4thgen shafts Frank, damn I may have to get one for my ws6 lol.
Old 07-22-2014, 02:52 PM
DANOZ28's Avatar
been awhile since i looked at driveshafts if i remember correctly the driveshaft shop had a really HD shaft rated at like 1000 hp but it was heavier than the inland aluminum only rated at 500 hp aprox same price so i chose the lighter weight. (going from memory) compare shipping weight to verify but i think the HD shaft was like 18 lbs vs maybe 10 lbs.
Old 07-22-2014, 02:56 PM
I cant see our shaft being any heavier, its going to use aluminum ends with a Billet yoke and solid joints.
Old 07-22-2014, 03:28 PM
DANOZ28's Avatar
what is your hp rating & what the shipping weight? im very sorry if im posting wrong info. EDIT i called inland & their 3" weighs 16 lbs and their 3.5" weighs 18 lbs. EDIT2 im stock i checked my ppwk and when i ordered a 3" i was told shipping weight was 13lbs and the shaft was 11lbs so i was given bad info it appears. (from summit)
Old 07-22-2014, 03:29 PM
do you have a stock diff or has it been changed
Quick Reply: The Driveshaft Shop 3.5" Aluminum DS?
