67 camaro restomod using original gas tank
I am looking to convert my stock tank out of my 67 camaro. It has the sending unit and fuel outlet as one piece. I am looking for a unit to supply my EFI with a replaceable adaptable unit. Any suggestions?
Any reason for wanting to keep the stock tank?
Tanks Inc sells both kits to convert the stock tank to EFI, and EFI specific tanks that are based on the OEM tanks and look/fit identical.
I just put one of these in. After adding everything up I felt I was better off getting one of these for my 67. Also has the baffle you will need. Worked our great and a much cleaner install than than external pump. Also has a stealth aeromotive pump that will support some hp for upgrades if needed. Heres where I got mine. http://www.sparktecmotorsports.com/am-18657.html
There is a company that makes a fuel pump with a foam baffle around it that you can install in your tank. I can't recall the name, but Car Craft or Hot Rod did an article on installing it. The problem is that it is about the same price as the Tank's Inc tank and takes more labor to install.
