CTS-V setup for GTO PRICE DROP!
Category: Brakes
Price: $650
Part Fits: 04-06 Pontiac GTO
Location (State): AL
Item Condition: Brand New
Engine: LS2/LS3/LS7/L92/LS9
LS Engine?: Fits LS Engine
Both calipers are New GM four pistons.
They have been painted red, with GTO on them in white to look stock. However, when I bled them some of the paint has started coming off from where I got fluid on them. They're notched on the back side of both calipers so the bolts don't hit also.
Brake rotors are drilled and slotted Volvo S60R that have been re-drilled to 5x120 bolt pattern and the hub centers opened up also. They were bought new from brake performance.com
Rotor diameter is roughly 13"
The brackets are aluminum and a very high quality piece. I got them from itsme4g63 on ls1gto. He is also on here, and I'm sure he will chime in on this setup. He knows how well it works!
This setup, WILL fit behind factory 17" wheels!
I had slight rubbing at the inside of my spoke with factory 18's, but a 3/16-5/16 spacer will fix this issue.
This will come with Pins and hardware as well as Brand new pads from autozone.
I'm asking $725 for the complete setup shipped!
This is a more than fair price for this setup!
I'm also open to trades and partial trades as well! Interested in MS3 cam, LS3 heads, nitrous setups, stock drilled and slotted rotors for 05/06 GTO....and LS swap parts for 82-93 S10. Let me know what you have!
This kit is absolutely amazing at stopping though! I've been using it for drag racing and a little on the twisties....but stopping at the track trapping 103+ I can ususally hit the first return road.... That was testing to see how well they stopped.... They STOP!
I will get some this weekend of the paint that was messed up by the fluid. Rotors have roughly 800-1000 miles. They've been on the car since August. I haven't driven the car a ton since then, but they have seen track duty a few times since they've been on it
Here is where the paint is messed up. It ran down the caliper before I could stop it when I was bleeding the air out, and I wiped it off. All looked good and a couple days later it looked like that.
BUMP It Back Up. How about $725??
Also interested in partial trades on MS3 cam, ASA cam, MSD 6010, Quick Fuel 750, GTO Drilled and Slotted Rotors, LS3 heads....TBSS parts....Let me know what you've got! Hell, make an offer on the setup!
And here they are behind the RTS's. you can't see them very well, but they were on there. I finished getting them on the night before I left for LS Fest 2013.
