01 Camaro parts for sale
Category: Accessories
Price: $2147483647
Part Fits: 93-02 Chevrolet Camaro
Location (State): TX
Item Condition: Used
LS Engine?: Fits LS Engine
THESE PARTS WILL NOT BE SHIPPED UNLESS OTHERWISE NOTED BELOW...i would be willing to deliver within about 30-ish miles of College Station where i live for any item over $50. if you are picking up the larger pieces that i can't fit in my car, we'll have to make arrangements to meet at my parents' place about 15 miles outside of College Station, either on the weekend or after 5pm during the week.
1) $250
rear hatch: tinted rear glass, hinges/mounting hardware, gas lifts w/torx mounting hardware, stock spoiler w/taillight housing, wiring harness & rubber boot (i cut the wiring harness about 4 - 5 feet after it enters the interior of the car, so there's plenty of length to splice it in)...DOES NOT COME WITH PLASTIC INTERIOR TRIM
2) $40 ea, or $75 for the pair
t-tops w/latches: weatherstripping seems to be in decent shape, there were no leaks that i could see while it was sitting outside waiting to be disassembled. the sun shades are not included, they didn't come with the car.
3) $25 (WILL SHIP)
t-top holders: the plastic t-top holders that are mounted in the rear hatch area, ebony plastic
4) SOLD
power side mirrors
5) $50 ea, or $85 for the pair
door glass: windows are tinted but tint is scratched up & will need to be removed, comes with the metal track that is attached to the glass, and i have the plastic retainer assemblies that bolt through the bottom part of the glass as well, the parts that keep the window from being able to just be lifted up out of the car.
6) $100 ea, or $175 for the pair
doors: these come as a shell with the hinges/mounting harware, interior & exterior handles and the locking mechanisms. the exterior side moulding is still attached. the keys, interior panels, mirrors, window/door lock controls, window tracks/motors, and window glass are not included. someone before me replaced the driver's side motor at some point and drilled several incorrectly-placed holes for mounting the replacement, but the motor was securely attached before i disassembled it, so it shouldn't be an issue to mount one up again. on the passenger's side, the OEM motor was still there riveted in place, and i very carefully drilled out just the rivets, leaving only the stock holes no larger than they were from the factory.
7) $50
"Berger panel": stock color, comes with mounting hardware
8) $25 for the pair (WILL SHIP)
Monsoon subs: these are the stock Monsoon subs in the rear sail panels, wiring harnesses intact, and screws/clips are included. don't know how they sound, but i can't see any rips in the surrounds, everything appears to be intact.
9) $25 (WILL SHIP)
Monsoon amp: just the amp & mounting hardware, bracket not included (it was broken so i threw it away). not sure how it sounds, there was no stereo or battery in the car when i got it.
10) $25 (WILL SHIP)
CD Changer: the stock 12-disc CD changer w/cartridge. don't know how well it operates, there was no stereo or battery in the car when i got it.
11) $15 (WILL SHIP)
trunk/hatch liner: this is the thin gray/white speckled liner that goes in the t-top area of the rear hatch. if shipped, it will be folded up to fit in a small box.
12) $15 (WILL SHIP)
scissor jack: stock scissor jack with handle, tie-down bolt, and plastic cover
13) $100 (WILL SHIP)
tubular 2-point subframe connectors: i think these are BMR SFC's, they are weld-in. they were welded onto the car, but i cut them off and cleaned them up a bit. if you care about looks, they need to be painted, but they are solid. these are off a t-top car and WILL NOT FIT CONVERTIBLES. BTW, these tuck VERY nicely, you literally could not see them on the car unless you were on the ground looking for them. pics added below to post #12.
14) $40 (WILL SHIP)
rearview mirror: pretty self-explanatory...just the rearview mirror assembly with the lights & the arm to mount to the windshield, along with the set-screw. mounting plate that the arm mounts to (the part that sticks to the glass itself) not included. pics added below to post #15
