Gauges for turbo build
I have almost completed my turbo build and will need to monitor the results. I know I need to get a boost and a wideband gauge for tuning and monitoring. Are there any other gauges that are must haves?
I run boost, oil temp, oil press, coolant temp, wideband, fuel pressure.
Im switching to an aftermarket ECU/gauge setup, and am selling all my autometer stuff.
PM me if you're interested, they are all the carbon fiber series.
My car is auto. So I already have the stock oil pressure on the dash, would it be better to have an aftermarket? I was planning on getting 3 total gauges. Should I do aftermarket oil pressure, trans temp or oil temp?
Get a wide band, fuel pressure, and boost controller/gauge. If you want to read other things like trans temp, coolent temp, etc get a aero force obd2 gauge to read those other pids.
I run a fuel pressure, truboost controller, and aem uago wide and in my 3 pod piller. I have the aeroforce in on of my vents to read trans temp and coolent temp.
