Vengeance Racing 5th Gen Camaro Camshaft Kit - SPECIAL PRICING INSIDE!!!!
Vengeance Racing
5th Gen Camaro Camshaft Kit SPECIAL!
Are you looking for a boost in performance on your 5th Generation Camaro for the best price on the market?
Vengeance Racing now has you covered with our
5th Gen Camaro Performance Package!
We have had incredible success with our custom camshafts and longtube header systems on 5th gen Camaros, and we wanted to offer a complete package that simplifies the process in pulling HUGE power and sound out of your L99/LS3 Camaro!
Our packages include the following:
- Vengeance Racing Custom Camshaft of your choice
- VR .660 Lift Dual Valve Spring Kit w/ Tool Steel Retainers
- Hardened Pushrods
- Melling High Volume Oil Pump
- 4 bar/3 bolt Timing Gear
- GM LS2 Timing Chain Damper
- ARP Cam Bolt Set
- GM Crank Bolt
- GM Front Cover Seal and MLS Exhaust Manifold Gaskets
- ARH 1 7/8" Longtube Header System
- 3" Catted Connecting Pipes
- Complete Professional Installation
- Royal Purple HPS Oil
- Complete Dyno Tuning w/ 12 months of free updates
Automatic Transmission Packages Include Everything Listed Above PLUS VVT/DOD DELETE:
- Comp 850-16 Performance Lifters
- GM LS2 Lifter Trays
- GM LOADED Valley Cover
- ARP Head Bolt Kit
- GM MLS Head Gaskets
- GM LOADED Front Cover
PACKAGE PRICING M6: $3,799.99
PACKAGE PRICING A6: $4,899.00
We are available Mon-Fri 9am - 6pm and Saturday 10am - 2pm
Feel free to call or e-mail us at anytime for questions or to schedule installation!
Still can't decide? Take a look at some of these YouTube idle clips of Vengeance Racing custom camshafts in our 5th Gens!
What would be your best cam for drag racing results on 91 gas? I have the Night Fury and hate it. Car put out 431whp. Most people with bolt ons are running that. Im looking for something that pulls really hard, and sounds pissed off. Thanks!
Adam
Adam
Ya, I either have the wrong cam, a bad grind, or my car just didn't respond to it. When I lived in TX and had 93 octane, the car did 453whp. Moved back to AZ and had it retuned and got 431whp. Once my car warms up, it doesn't even sound like it has a cam in it. I'm going to do a 418ci build in the coming months, but want the car running a little stronger before camaro fest.
Unfortunately I have not switched cams out yet. When I wrote the initial inquiry about switching cams, I had just had a differential built, and I was naive and actually thought the guys building it, were able to do just that. You would think with "driveline specialists" in the title of their shops name, they should be able to go pull off a simple diff build. That is not so. Once I find someone else that will take my money and actually successfully perform the task I asked for, then I will move back up to the engine bay, where I will then be giving you a call for my next cam! Thanks for checking in!
