PRC 247cc heads for boost?
Old 02-04-2014, 07:27 PM
Papa Wells's Avatar
Default PRC 247cc heads for boost?
Hey guys. I've got a 408ci iron block with 317 heads and an F1-A ProCharger, looking to make 800ish rwhp and later on 1000+rwhp, and I'm looking into a different set of heads. I've been looking at the Texas Speed PRC 247cc heads which have a 3/4" deck thickness, and seem to flow as well, if not better than many other aftermarket heads. My only concern is that I can't seem to find anyone using these on a boosted application, or any reviews at all really.
My question is, has anyone used these on a boosted setup, or does anyone know if these would work well with what I'm wanting?
Thanks!
Old 02-05-2014, 09:28 AM
Papa Wells's Avatar
Bump..anyone have experience with these heads on a boosted setup?
Old 02-05-2014, 11:39 AM
Ryans99ls1's Avatar
its got a 3/4" deck with solid flow numbers. they are a good head for the money. Im going to run their small bore head on my car. If you spend more money on another set of heads will you make significantly more power? probably not a substantial amount but it all comes down to what you can justify. i cant see spending hundreds more when you can turn that jam **** a lil more and make up the difference. Heads are a lil less important in FI, the 3/4 deck is the selling point IMO
Old 02-05-2014, 11:47 AM
Papa Wells's Avatar
Right, and honestly I would rather not spend the extra money right now because money is tight at the moment...but I'm worried about lifting the heads with my 317's, that's the only reason I'm curious about the 247's. The motor isn't in the car yet, so if I can sell the brand new 317's, that's what I'd like to do in order to get these.
Old 02-05-2014, 04:58 PM
Daniel Nicastri's Avatar
What about the lsa heads they would be cheaper ?? R they a better head
Old 02-06-2014, 08:43 AM
Philly Fakeout!
BadCompanySS's Avatar
They are a good head for boost. All of the same key features as say an AFR or TFS head you want to see on a head going on a boosted application. Good flow numbers as well. Like mentioned above, flow numbers aren't as critical with boost but you aren't giving any up to the other guys anyway. Why spend the extra money to do the same thing?
Old 02-06-2014, 09:48 AM
Papa Wells's Avatar
Awesome. I'm not very worried about the flow numbers as I know they're good, just wanting something with a thicker deck so I don't have to worry so much about running more boost. Many tell me my 317's will be fine at 17psi but if I can sell them now, I would rather not take a chance and go ahead and get the 247's.
Old 02-06-2014, 12:03 PM
venom ws7's Avatar
I'm going with these heads on my build 408ci twin 7275s turbos I can't wait
Old 02-06-2014, 12:50 PM
trans2000am's Avatar
317's running 21lbs no issue yet
Old 02-07-2014, 06:40 PM
I8UR4RD's Avatar
few reasons i bought my PRC's.
obivously the 3/4 deck and the extra insurance.
the fact that i can still use them on a 6 bolt block
They are awesome heads with great work done on them.
For my F1 build....anything that helps make more NA power is a good thing because it offsets the parasitic loss that the blower sucks out of the motor. i would not give a **** if they only net 20 hp. that 20hp can be used to turn that damn blower a bit faster.
Old 02-10-2014, 08:33 AM
Papa Wells's Avatar
Very nice, are they ported or just stock? Who did the work, if so? And what head gaskets?
Papa Wells's Avatar
Thats awesome! Should be a sweet setup.
Old 02-10-2014, 08:34 AM
Papa Wells's Avatar
Originally Posted by I8UR4RD
few reasons i bought my PRC's. obivously the 3/4 deck and the extra insurance. the fact that i can still use them on a 6 bolt block They are awesome heads with great work done on them. For my F1 build....anything that helps make more NA power is a good thing because it offsets the parasitic loss that the blower sucks out of the motor. i would not give a **** if they only net 20 hp. that 20hp can be used to turn that damn blower a bit faster.
Thats true, I completely agree! I'd love to get these for mine but I guess we'll just have to see if my 317's sell. If not, I just hope they hold!
Old 02-10-2014, 08:41 AM
No porting stock valves upgraded springs of course used a ls9 head gasket I know I'm pushing the limits but that's all I could afford when I built the motor
Budget LS Guy's Avatar
317's are a great turbo head i've heard. Get them reworked though with beefy high lift springs of course. The turbo will do all the work imo. Those fancy heads aren't necessary.
Old 02-10-2014, 10:14 AM
Papa Wells's Avatar
Mine are advanced induction fully ported 232cc heads, stainless valves, dual springs, etc. LS9 head gaskets that are copper coated, arp studs. I have an f1-a ProCharger, and nobody is offering me any reasonable amount for my 317's so it's looking like I'll have to keep them. I just really hope they don't lift. I'd like to be able to make at least 900 with mine.
Papa Wells's Avatar
Awesome, I have the ls9 gaskets as well that I copper coated for some extra insurance. Mind sharing hp numbers? I'd like to know
Old 02-10-2014, 10:23 AM
BMF_Racing's Avatar
Thumbs up
I have the PRC 255 6-bolt heads on my new engine (2013 build) in my sig. I love these heads. Very good for the $$$ IMO.
As far has the 317's, we have them on a forged 6.0L and have had a LF 85mm at 26psi and 22* timing on E85 and the heads did not lift. Thats north of 1150whp. ARP studs and LS9 gaskets. Id say it is at its limits for sure as far as lifting the heads.
Good Luck.
Old 02-10-2014, 12:37 PM
Papa Wells's Avatar
Good Luck.
Christ! That's awesome. Makes me feel a little better about running mine. Hopefully, if mine don't sell, I can upgrade to the PRC's in the future. Thanks for the reply.
Old 02-10-2014, 12:58 PM
Goosecaddy05's Avatar
i went with prc heads for my motor.... plan to go boosted later on... the 3/4 deck is def a reassuring point... and they're hard to beat for cat heads when looking at price
Quick Reply: PRC 247cc heads for boost?
