Intercooler nitrous spray bars.
Old 02-09-2014, 07:29 PM
Ph.D. in HUBRIS
custm2500's Avatar
Default Intercooler nitrous spray bars.
I am arguing with some tuners about the improvements of wasting nitrous on cooling your intercooler. Does anyone have dyno sheets of with and without intercooler spray bars. or track times. Obviously any data that shows if they have any effect and how much if any.
Thanks.
Old 02-09-2014, 07:58 PM
Truck Sponsor
TrickPerformanceProducts's Avatar
Which side of the real are you on?
Old 02-09-2014, 08:41 PM
Ph.D. in HUBRIS
custm2500's Avatar
They are worthless and dumb. I found some data that they make no power unless the nitrous is sucked into the intake of the engine after "cooling" the intercooler.
I am going to make real power spraying nitrous into my engine and adding fuel so that I know what is going on, not trying to cool my intake temps by a few degrees and blowing my engine because it leaned out too much.
Old 02-09-2014, 08:51 PM
Forcefed86's Avatar
It definitely improves the efficiency of the intercooler and will produce more power.
I'm with you though. IMO it's a waste to not run it through the motor.
Truck Sponsor
Yep that's the stuff I see. 10+ years back.
The amount of time it takes to cool an aluminum core
And the hot ambient air
Plus then cool the air that is hauling *** on the inside of the core.
It just doesn't happen.
Now dump the shot inside. Cooling isn't much until you start getting into larger shots.
Old 02-09-2014, 10:49 PM
Silver408z's Avatar
If you need cooler IAT's, do meth or water injection
Old 02-11-2014, 07:18 AM
chuntington101's Avatar
if you are going to spray an air to air intercooler with anything, use water! its been used in AC units for YEARS and works a treat (esp on thicker cores as increase the thermal efficiency as the ambient air heats up slower through the core).
Old 02-11-2014, 08:19 AM
Forcefed86's Avatar
But make sure NOT to spray water on the IC at the track! I about took my crowbar to a kid that sprayed the lane down with water before my run.
Quick Reply: Intercooler nitrous spray bars.
