LS7 clutch?
Old 02-09-2014, 08:31 PM
02silverbulletZ28's Avatar
Default LS7 clutch?
i had a spec clutch in my car that went out on christmas, i put a ls7 clutch and flywheel about a month ago. about a week ago i did a burn out through 1st and 2nd i went to hit 3rd and the clutch pedal was almost on the floor, i pumped it and has been fine for almost a week my car started spinning the other day so i layed into it and it was on almost on the floor again, any idea what would cause this? someone told me it might be slave cylinder?
Old 02-09-2014, 08:45 PM
ULTIMATEORANGESS's Avatar
is your fluid ok?
Old 02-09-2014, 08:54 PM
N20zuki's Avatar
https://ls1tech.com/forums/manual-tr...-write-up.html
Old 02-09-2014, 08:58 PM
yes clutch fluid is ok when i got the car the fluid was black and kind of thick i flushed it before the clutch went out and has been fairly clean since
Old 02-09-2014, 09:21 PM
BrntWS6's Avatar
Could be the slave if you didn't change it, it's a good idea with any clutch swap. Also, clean out the clutch fluid reservoir religiously. I clean mine out almost every time I drive the car. What kind of power are you throwing at that clutch?
Old 02-09-2014, 10:04 PM
only mods i have is long tubes, 3" exhaust, slp lid and short throw. at the time my clutch went in my brother did most of it as i work 6-7 days a week so i was limited on time he told me the slave cylinder and throw out bearing looked good so i didnt mess with it, i wanted to go with a tick master cylinder, im going to try what N20zuki posted and if that doesnt work i guess ill be buying a slave cylinder. i just dont want to mess up this clutch as i just installed it
Old 02-10-2014, 10:01 AM
03Sssnake's Avatar
You will not regret going with the Tick MC, its a great part and will probably resolve your issue. If it doesn't, at least you have removed the MC from the equation and future proofed the MC as a possible issue down the road.
Old 02-11-2014, 08:08 PM
ive read reviews that its hard to set up a tick adjustable mc?
Old 02-12-2014, 07:35 AM
z28SSilvest's Avatar
I change my slave cylinder every time I change clutches and haven't had any problems with the pedal sticking.
Old 02-12-2014, 08:59 AM
Blownbayou's Avatar
Had to mod my stock master to accommodate my LS7 clutch swap.
03Sssnake's Avatar
installation is kind of a bitch, but actual adjustment is pretty easy....
Quick Reply: LS7 clutch?
