Extremely lean LTFT's
Old 02-12-2014, 05:23 PM
JRENIGAR's Avatar
Default Extremely lean LTFT's
I need some help from the fueling experts here. I have a 2000 ws6 fully stock auto car. I installed an ls6 intake and removed but did not take off the egr pipe that went into the ls1 intake. I simply unplugged the connector to power the egr motor until my Lt's get here. I also removed the air injection hoses and capped them off near the mani's. The car has an SLP ram air kit with a smooth bellows and a k&n filter. Stock car other than that. I was logging LTFT's and they are around +19+22% while crusing and go to 25% when WOT. It starts right up and runs good with no hesitation at all. Motor sounds beautiful and I am not getting any KR that I can remember. I replaced the fuel filter 100 miles ago, replaced the plugs with NGK v-power plugs that are stock heat range and run a can of seafoam through the tank at the same time. Why is my car's LTFT's in the +19+22 range? Is the egr unplugged and the addition of an LS6 intake capable of causing this alone or is there something else I should be looking for? Thanks for any help.
Old 02-15-2014, 11:16 AM
JRENIGAR's Avatar
An update: I logged my STFT's and they are +5 to-3% on both banks while crusing down the highway in OD and running 1800 RPM or so. I also logged my o2 sensor voltage to make sure they are good and they were back and fourth between 0.78v to 0.11v on both banks consistently so no problem there that I can tell. I did a 2nd gear WOT run through 3rd and no KR whatsoever and the car runs absolutely great for a stock car. On the WOT run the LTFT's went straight to +25% and didnt budge at all. I also noticed that when I come to a stop in gear at idle the RPM is about 550-600 and the STFT's go to like +19 to +22% and at the same time the o2 voltage drops to around 0.05v or so. WTF? I have had the battery cable off for quite a bit while replacing the rear cover seal due to a leak so the memory should have been reset. I installed new intake manifold gaskets and am pretty sure there is no vaccum leak.
Old 02-15-2014, 11:19 AM
JRENIGAR's Avatar
If this would be better suited in the tuning section Moderator please feel free to move it. Thanks.
Old 02-16-2014, 05:51 PM
JRENIGAR's Avatar
Finally threw a code of bank 1 lean. Where to go from here?
Old 02-17-2014, 07:14 AM
Exidous's Avatar
Your tune is obviously lean or there is a leak somewhere in the exhaust. STFT isn't really important as they simply drive your LTFT's. If you are off 20% in the VE table and your LTFT are 18% your STFT will be 2%. You want LTFT under 5% each.
I'd go through the exhaust first. Check to make sure the EGR valve isn't open. A leak in the intake could be at fault as well. What are your IAC counts at hot idle?
Old 02-17-2014, 01:06 PM
JRENIGAR's Avatar
How do I check the egr? What are IAC counts?
Old 02-17-2014, 02:14 PM
Exidous's Avatar
Not too sure one the EGR position but IAC is your Idle Air Control.....The valve that controls airflow at idle. If you have a leak it will be at Zero. If the motor needs too much air it maxed in the 300's. The later is usually remedied by drilling a bigger hole in the TB blade but that's not your issue here.
I guess with the EGR take it off and see if you can pass air through it.
Old 02-17-2014, 07:51 PM
JRENIGAR's Avatar
Ill give it a try. Thanks.
Old 02-18-2014, 08:21 PM
joecar's Avatar
MAF may be under-reporting, it may be dirty/oiled due to K&N filter.
Old 02-19-2014, 08:28 AM
JRENIGAR's Avatar
Well I cant see IAC counts with this predator Im using to datalog. I did look at the cyl misfires and all of them have misfired a different # of times from each other. I am not getting the multiple cyl misfire code or any other misfire codes either. I can faintly hear a thud in the exhaust evry once in a while when its just idling. Stock crap is too quiet to really hear a good exhaust note through. Im almost positive that I cleaned the maf when I first got the car but I will try it again just to be sure.
Old 02-19-2014, 12:37 PM
JRENIGAR's Avatar
Cleaned the maf and no difference. I also unplugged it while running and no difference exept when I first do it and the car stumbles just a sec then goes back to normal. Headers came in so I guess next Ill do a compression check before mm's and headers go on. I think the comp check would be done the easiest with no manis or headers on the car.
Old 03-01-2014, 11:18 AM
JRENIGAR's Avatar
Got a can of carb cleaner and sprayed it all around the intake where it meets the heads and where the injector orings are while car was running with no change in idle. This leads me to believe there is no intake leak. I also installed new intake gaskets last week when the LS6 intake was installed. Done comp check and all 8 were 133-135psi. Installed poly mm;s, headers, and oryp with new gaskets and reinstalled factory catback. New plugs, wires, and Bosch o2 sensors also just to be sure. Its still doing the same thing. No codes this time exept the p1637 code that says"Can link ECM/ABS control module circuit network" on the predator tuner. I drove the car and its showing +25% LTFT when ideling and o2 voltage is 0.00v to 0.10v. Just crusing its showing +19% to +22% and the o2 sensor voltage is 0.11v to 0.87v constantly sweeping back and fourth. Whats going on? I have never had a mechanical issue I couldnt figure out on these cars but this has me stumpped. Im gonna take it to a tuner to have the tune and computer checked but wanna make sure I have the basics done beforehand and try to avoid silly B.S. problems that I could have fixed before paying someone else to fix it. Any Ideas? I ahve a friend with HP Tuners and a laptop thats gonna come over tomorrow and help try to diagnose it but honestly he's not very good on it just able to copy n paste crap from one file to the next and datalog a bit with it. if there are any specific paramaters we should be looking at with his computer that this diablo predator wont monitor let me know. Feel free to P.M. me if you want. Thanks to anyone who can help try to figure this crap out.
Old 03-01-2014, 12:41 PM
CRTD's Avatar
if the fuel trims are lean at idle only then you are looking for a vacuum leak most likely. if fuel trims are lean at all times you are looking at poor sensor performance, poor fuel delivery or quality, outside air entering the exhaust stream near the o2 sensor (bank specific). or lastly, calibration needs edited. good luck!
Old 03-01-2014, 01:06 PM
JRENIGAR's Avatar
The trims are lean all across the board. They are the most lean at idle and at WOT. When this happens at idle the o2's go to almost no voltage. When crusing they are still really lean just not as much as when Ideling or WOT. Thanks for responding.
Old 03-01-2014, 05:32 PM
LS1Tech Sponsor
COSPEED2's Avatar
You pretty much summed up the lean problem. Your headers seem to be causing it. Do you have any tune on it besides the generic Diablo tune on your predator?
Old 03-01-2014, 08:14 PM
JRENIGAR's Avatar
It was like this before the headers went on. It needed motor mounts and the factory mani collector bolts were rusted so I just went ahead and bought the LT's to install when the mm's were done. I didn't think headers could make it lean enough to skew the Long term trims to +25%.
Old 03-01-2014, 09:18 PM
LS1Tech Sponsor
COSPEED2's Avatar
Oh yes indeed.
You will need a tune. There is no doubt.
Old 03-01-2014, 09:41 PM
JRENIGAR's Avatar
My last car had a Frost tune with these same mods and it made a world of diff. I did run the car daily for a short while before the tune. I didn't log the fuel trims but the car didn't have the problems this one is having.
Old 03-01-2014, 09:49 PM
LS1Tech Sponsor
COSPEED2's Avatar
Every car is different.
Old 03-02-2014, 11:21 AM
JRENIGAR's Avatar
I agree.
Quick Reply: Extremely lean LTFT's
