Thumpy turbo cam?
Thumpy turbo cam?
Okay, so this is an odd request. The Formula in my sig, is my wife's. In the somewhat near future, the tired N/A LS1 is getting pulled, and a turbo 5.3 setup will be in its place.
I have my wife sold on the power potential, but not on the sound. She loves the sound of a big cam, cut on a low LSA. The more it thumps, the more she likes it.
The problem is, low LSA cams, and big cams are not good for turbo setups.
Are there any cams out there that would do well with a turbo and still have a little thump?
1 Post
LSA isnt everything as far as idle characteristics. Duration and the tune itself play a big part too. Martin Smallwood did my cam and I should have a start up video next week. It should hit pretty hard for a turbo cam. Playing with the tune also can net you more lope from a less aggressive cam
*Is willing to bet good money that said wife forgets all about that silly lope sound after she falls in love with the new "sound of her life" so to speak... that of a turbo coming to life and the sweet woosh of a blow off valve.*
I would love to hear/see videos of these in action. Not only how they idle, but how they perform under boost as well. Then I can have something to show my wife that it can still sound and perform decent at the same time. Cam specs would be great also.
Thanks guys.
I wanted the same thing on my first motor and Martin recommended the TU2 this was before he was grinding his own. But I did like the sound out of it and made nice power for an off the shelf cam
And fwiw when I went to a show I wanted to sound even meaner so I just turned down the idle and it ran just like my na motor did.
1999 Camaro SS S480 Turbo Tu2 Cam Only - YouTube
Thank you for posting the vid. It sounds decent. I know this won't make her happy enough though, so I am hoping I can find something a little more rough and thumpy.
Here is how the car currently sounds. I know I probably won't be able to get a good turbo cam to sound as rough as the MS3, but I'd like to find something that is as rough as possible and still be a good cam for the turbo setup.
http://www.streetfire.net/video/formula-first-start_167898.htm
http://www.streetfire.net/video/form...art_167898.htm
You can get it close. You do your own tuning??? That's all it will take to get it to sounds nasty. I wanted the same thing and i was pretty happy with it but the better the tune the more smooth it ran. Personally i think the new cam sounds too tame but its all in how it performs so figured i would make that trade off.
Just like Camaro9969 said just ask your tuner to play with the tune a bit. This is a buddies TU1 that sounds pretty mean. New muffler and side pipe turbo truck - YouTube
This is more along the lines of what I was thinking
http://m.youtube.com/results?q=cammed%20turbo&sm=3
This was his cam specs > 238/242 .609/.612 113+4 cam
Anyone know if it would do decent as a turbo cam? You can put something mean into a turbo car, but it doesn't mean its going to perform well.
Well, as bad *** as that 238/242 cam sounds, I just think its too big to make a decent turbo cam. I found the video randomly on YouTube, and it would seem he had the cam in the car when it was NA, and added the turbo later. And although it seems to drive well;
http://m.youtube.com/user/ssinister550
I think going that large probably has a lot of lag down low.
I'm thinking of staying in the low 232/234 .050 and around 600 lift on a 113 LSA may be able to keep me with some decent chop and still perform well.
I have been reccomended again to contact Brian Tooley Racing to get their opinion as they apparently have good spec'd cams that fit what I am looking for here.
In the mean time, if anyone has any other reccomendations with videos, I would love to hear them.
I'll need to go elsewhere for this. I contacted Martin at Tick, and Brian Tooley to see what they had to say. So far Allen from BTR has got back with me saying if I went with a S475 that he could get me a cam that sounds like what I am looking for. But, even though I had considered an S375, I was steering towards a PT7675 due to the ginormous size of BW's housings and the lack of precious real estate I have under the hood.
have you considered going with a D1SC instead of a turbo? Seems like it would get you where you wanna go while getting that chop your looking for in a cam and you obviously have been down that road before, so is there some particular reason you wanna switch it up for her car?
