Who makes intake manifold spacers?
I've seen a few posts on here about intake manifold flanges, and them being available. The one thing I can't find is who makes them. Anyone know? I need some to make some spacers to bolt down my manifold. I spoke with FAST, and they said it was fine to mill the LSXr, but every machinist I talked to said it was a crazy idea to attempt to grind the plastic manifold.
Moderator
I'm pretty sure Comp (or one of its sister companies like RHS) makes them.
How thick do you need? For what it's worth, I noticed that the truck engines use a plastic spacer between the head and manifold. It looks the be about 1/4" thick. Might be a better option that a pricier set of aftermarket spacers.
Got the spacers in from flat out gaskets. Test fit with FAST intake, and it still fits like junk, so I grabbed the old truck intake, and it bolted down just fine. What gives? Is there an issue with fitment using the FAST? I'm about to throw this junk in the trash, and just run stock. With the intake on, I still won't be able to put injectors in as it is hitting the top of the port. Here are the spacers if anyone's interested.
^ Yes, they only work with the tall deck blocks.
I had the heads milled down about .045" total to get to 63cc. Everything else was at stock spec. The manifold bolted down to another long block, so I figured my block was milled to fix the deck. The pistons were under the deck when I measured, so I assumed it was close to spec. I don't have the measurements in front of me, but I needed to get .045" gaskets to get the clearance where I needed it.
if your heads are milled your alignment problems are because the heads are sitting lower...
spacers would only make the problem worse.
with milling the heads .045... the only thing that fixes your issue is to Mill the intake to match
Mill the heads, mill the intake
raise the deck, add to the intake
the problem becomes that you went for extra compression in the wrong spot by going to a milled head to reduce the chamber size
should have gone for different pistons to change compression.
otherwise, as you have found out, intake to head geometry gets messed up.
Would you recommend getting a custom intake, or milling the heads to work with the stock manifold dimensions?
