Fender help
Fender help
Hey guys I am a newbie!
This is my 1st post. My problem is I put on a new OEM fender and the door is hitting the fender when you open the door. I know the fender needs adjusted. The guy who put it on wont come and adjusted it can someone please help me! Thanks guys
It is not that difficult to adjust it yourself. I just replaced my passenger side fender which was cracked with an oem replacement fender and even when I first installed it, it did the same thing as yours and rubbed the door.
After a couple hours of messing with it, I just loosened the bolts up and pulled the fender forward some. It does have some adjust-ability.
Check out this thread an maybe it will help. If the tabs on the bottom are bent from a jack or whatever this could be the case. Has happened to a lot of us
https://ls1tech.com/forums/paint-bod...-gap-pics.html
