going proratchet to Quarter Stick
I have a B&M pro ratchet shifter for my th400..If I decide to go to a b&m or hurst Quarter Stick, Does the shifter Cable need to be changed?
Thanks!
Thanks!
In-Zane Moderator
Check the part numbers through summit. They will tell you which number fits they pro stick and ratchet, that would be a reason to use the pro stick, you know the mounting would be identical. I had one, I love the gate shifting over the ratchet. Got a tci outlaw on the way. Of course had to order a damn 4 speed gate too.
I would think that if you stayed with the same brand (B&M), the cable would not change. Make a call to Summits tech line and ask them. I have made a few shifter plates for different shifters and although I haven't installed the cables, I've not noticed differences in cables.
