Is there really any danger in driving the V with no exhaust?
I have always heard tales that if you a drive a car without an exhaust the cold air after shut down will warp the valves over time. That just doesn't seem to make any since to me since there are still the resonators and headers which will be hot and when your engine is running it sucks in cold air. Seems like complete BS. Other than being annoyingly loud, is the really and damage to be done to the car driving with the exhaust off? It is something that has been weighing on my mind recently. Would like to know others input, thanks.
ive ran open header when i put my diff bushings in to make sure every thing was good. the stabiltrak went crazy and nearly lost control... felt like the brakes grabbed when i was at WOT. rear end got loose and swayed... not sure if it was bad luck or what as i would love to run some cut outs and no one seems to have that problem
No, it's because of the exhaust. I believe the yaw sensor is under the center console area which is about where open headers dump. The vibration sets of the stability control. I run mine full off with cutouts open or it will try to kill you.
In conclusion: it sounds fantastic but performs like **** (and dangerous if you aren't expecting that 4th gear fishtail). I don't suggest running it that way for an extended period of time unless you have to for some reason.
The car was built to handle a certain way for a 4000 pound car, when you start changing things , other things might start to act different.
Now I'm not an expert just a aerodynamics and CTS-V fan.
So you think that in a car going above 100 mph (4th gear) in a something that creates no downforce (the CTS-V makes lift like most cars ) That a new charged air flow (high pressure) under the car will have no affect on the handling??
You might also be surprised how little it takes to upset a car at speed. Judging from how condescending you are instead of sharing ideas and having an adult conversation about a issue that affects our cars in a very limited case I'm forced to assume that you haven't setup up a car for more then "street" use
Isn't the affect these people are experience is stability control activating, and locking the rear wheel?? I'm not sure of anyway that exhaust could lock up a wheel by it shelf.
So on the F1 car the energized air flowing over the diffuser raised the pressure difference and makes more downforce adding more rear end traction.
Since our care is built more like a wing to make lift to help with gas mileage and such we don't make downforce.
so adding even more energized air to the bottom of the car can make the rear end light. couple this with all the air flow that is already under the car at 100 mph and I can see how this could unsettle the car and cause the stability control to step in.
Again i'm not an expert when it comes to air flow I just know that at speed our car is not stable and adding even more lift would not be a good thing.
