4L60e interchange
Old 03-05-2014, 06:44 PM
David Ferrell's Avatar
Default 4L60e interchange
The transmission in my 1999 Camaro went out and I'm looking to replace it, I've found a 1996 Camaro with the same engine and transmission combination (3.8 V6, 4L60E). Would the transmission from the '96 Camaro work in my '99 Camaro?
Old 03-05-2014, 08:36 PM
01ssreda4's Avatar
Probably not, and here's why.
https://ls1tech.com/forums/conversio...ns-4l60es.html
Old 03-06-2014, 09:53 AM
Originally Posted by 01ssreda4
The only thing I can find that relates to my question in that thread is that the 93-97 models are electronically the same. But what about the '99? What exactly is different about it?
Old 03-06-2014, 02:22 PM
Moderator
mrvedit's Avatar
First, I assume then that both the recipient and donor cars have V6 engine. Please confirm.
If true, both should be "LT1 style" transmissions with a 298mm input shaft. Since '96 and '99 4L60E are electrically identical, I would expect them to interchange, but I have little experience with V6 cars and 01ssreda4 may know something about these years that I don't. (Note that no 4L60E from '94 or '95 will interchange with a later year.)
Old 03-06-2014, 05:13 PM
Yes, both cars have the v6, same engines; 3.8 Series II
Quick Reply: 4L60e interchange
