Help with plug reading.
Old 03-14-2014, 04:34 PM
Cowboy97's Avatar
Default Help with plug reading.
Ok I sprayed the car with a 100 shot and shut it down. Plug is a BR7EF with 4 degrees pulled and it's in the car in my sig. I was having a hard time getting a good picture, but the ring is slightly discolored and the strap has a light tan spot going about a 1/8 inch from the end you can see the line. Let me know if I need better lighting.
Old 03-14-2014, 04:58 PM
brandon@nitrousoutlet's Avatar
Can you cut the threads off? I need to see the fuel ring at the base of the porcelain.
Old 03-14-2014, 05:54 PM
Cowboy97's Avatar
Old 03-14-2014, 06:27 PM
Carter01's Avatar
Timing looks good. Fuel is a little light imo. Heat range looks good.
What n2o and fuel jets?
Old 03-14-2014, 06:47 PM
Cowboy97's Avatar
N2O is a 52, and fuel is a 27.
Old 03-14-2014, 07:05 PM
Cowboy97's Avatar
I thought the color looked a little lean. I've got a whole bag of jets, I can go one step bigger.
Old 03-14-2014, 08:05 PM
Carter01's Avatar
I'd probably put a 29 in it at least.
Old 03-15-2014, 08:13 AM
Cowboy97's Avatar
I've got a 31, would that be too much?
Old 03-15-2014, 12:08 PM
HCI2000SS's Avatar
I'd go 29-30 and see what happens
Old 03-15-2014, 12:30 PM
Carter01's Avatar
No a 31 won't be too much. Might be a tad on the rich side but some engines like a little richer mixture. keep cutting plugs and you will know.
Old 03-15-2014, 12:34 PM
Carter01's Avatar
Just a reference point for you. This plug is years old when i first started tuning ls motors. Little rich but not bad, decent timing mark and good heat range.
Old 03-15-2014, 02:09 PM
Cowboy97's Avatar
Thanks for the help!
Quick Reply: Help with plug reading.
