S480 upgrades
S480 upgrades
I currently have a 408ci motor with Trick Flow 220 heads and a Pro-Flo intake, it was running a GT4202 with 1.15ar TW but it maxed out at only 14psi making 620rwhp though a T400,
Now I've for a S480 with 96mm 1.32ar TW and am aiming to run 18-20psi My goal is 850+rwhp
If the 80mm unit can not make these numbers or I get board and want more later on and I simply change out the 80mm comp wheel for a 88mm wheel ?
cheers
cheers
yeah dude you gotta look beyond the surface in those advertisements. plenty of 4 and 6 cyl cars making 1000 plus on Gt42s. with the turbo and boost your looking at in your first post you can hit your power goal on PUMP GAS.
Im confident the S480 will net me 850+rwhp
The motor and fuel system is up to the job, running 2x 044s and 1800cc injectors
Biggest thing holding me back once the numbers get higher will be the 3.5" dump pipe,
An 87mm 1.15 A/R is more than enough for your 800+ HP goals. It is getting a little sad the sheer number of 400+ cubic inch guys that come here complaining that their turbo is maxing out at 75% of its potential. I've seen V8s hit 900 HP on a Billet 7675.
do run a 4 inch dump now but I,ve cracked 1000rwhp with a 3.5inch dump !!!you could upgrade to billet 80 !!! my upgraded 88mm unit had the race cover machined out so 88mm wheel would fit !!! cheers
