MSD shift light, Spohn bump steer correction, battery cut off switch
Category: Accessories
Price: $1
Part Fits: 2010+ Camaro, 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V
Location (State): VA
Item Condition: Brand New
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6
LS Engine?: Fits LS Engine
$45 - MSD shift light with 6000 module
$20 - Battery cutoff switch
$100 - Spohn bump steer correction kit. Brand new, test fit only but didnt fit with my 17" wheels, need 18" min.
$40 - 3rd gen t top case. great shape, no rips, zipper is a little catchy but works.
SOLD
SOLD - LS7 clutch and RAM lightweight flywheel. brand new.
SOLD - LS6 heads, 243 triangle casting. One cylinder dropped a valve and beat up the CC a little but can be repaired. The rest of just needs a good cleaning and might as well do a P&P/valve job at the same time. Inlcludes 7in/ex valves and all rockers, need one exhaust and one intake valve and springs.
SOLD - Truck MAF 85mm with pigtail.
$SOLD - Brand new clutch install parts. GM slave cylinder 24264182 (newer style), GM seal 89060436, GM bearing 14061685, shim, ARP flywheel and pressure plate bolts, Tick speed bleeder. Prefer not to split up.
$SOLD - Improved Racing LS1 oil pan baffle. Brand new.
$SOLD - Set of 8 LS6 sodium filled exhaust valves. used
$SOLD - JWIS timing chain with gears. used <20K
$SOLD - LS6 oil pump. used ~5K
FREE STUFF
wheel bearings with play. good for core or custom rebuild
