Sucky dyno numbers
Sucky dyno numbers
You might have seen my posts about struggling with what I think is light flywheel stalling in my recent rebuild but, perhaps related to that is that my dynojet numbers suck given my mods. Other than "get a new tuner" anyone with thoughts?
389hp, 363tq from
389hp, 363tq from
- LS6 block w/ forged pistons, forged H Beam rods & balanced crank
- Trick Flow 220 heads
- Comp Cam 229/239 .627"/.621" 111.5+3
- 63lb injectors
- Fast 92
- 90mm LS2 TB
- LS7 clutch and light RAM flywheel
- high vol/high press oil pump
You might have seen my posts about struggling with what I think is light flywheel stalling in my recent rebuild but, perhaps related to that is that my dynojet numbers suck given my mods. Other than "get a new tuner" anyone with thoughts? 389hp, 363tq from[*]LS6 block w/ forged pistons, forged H Beam rods & balanced crank[*]Trick Flow 220 heads[*]Comp Cam 229/239 .627"/.621" 111.5+3[*]63lb injectors[*]Fast 92[*]90mm LS2 TB[*]LS7 clutch and light RAM flywheel[*]high vol/high press oil pump
Dyno numbers can be funky though depending on lots of things. Tuner, calibration, condition of the equipment etc. I'd think with your setup you be above the 400 mark for sure.
389hp, 363tq from
389hp, 363tq from
- 63lb injectors
- Fast 92
- 90mm LS2 TB
You should probably match the TB to the intake as it is currently acting as a restriction. And do you have Headers installed? (not familiar with what was already in your car)
i'm definitely not ruling out the tuner... the low numbers + his apparent problems solving the return-to-idle stalling make me think that may be the primary issue
yes, I have Kooks headers (they are 1 3/4 and not 1 7/8)
and most of my brain agrees that 50 rwhp over stock is in the right ballpark but I also see Fuzzy making 420 something with no heads, lolly making a reported 422 with 215 heads and the "how to I make 450-500hp?" thread recommending h/c/i to make 450 and it makes me wonder
I have a racetronix kit I'm going to eventually install and perhaps a 255 fuel pump. My injectors show like 1-7% capacity (I think)
I think the 'one dyno vs a different dyno' could account for 20 hp or so but yeah, it sounds like you have what's being suggested in the other thread to make 450.. Which I'm not sure would likely be just the dyno.
But I'm gonna bow out here, since what I've heard is what you've heard and is all I really know, and that means I don't really know. Good luck.
i'm definitely not ruling out the tuner... the low numbers + his apparent problems solving the return-to-idle stalling make me think that may be the primary issue yes, I have Kooks headers (they are 1 3/4 and not 1 7/8) and most of my brain agrees that 50 rwhp over stock is in the right ballpark but I also see Fuzzy making 420 something with no heads, lolly making a reported 422 with 215 heads and the "how to I make 450-500hp?" thread recommending h/c/i to make 450 and it makes me wonder I have a racetronix kit I'm going to eventually install and perhaps a 255 fuel pump. My injectors show like 1-7% capacity (I think)
It's hard to tell whether there's a problem or not. It does seem a little low, given your heads, but it is a LS6. The compression check couldn't hurt.
Have you tried a 4.0" intake with 4-ply silicon couplers, a 4.0" LS3-style MAF, insulated airbox, and a relocated low thermal impedance IAT sensor? You could implement most (if not all of it, depending on your airbox selection) for about $400, and it'll support future engine modifications.
The bigger intake and IAT aren't a bad idea - there's a thread out there on it that I'll find when I'm off mobile.
The thread will prob answer my questions but doesn't the IAT bung require welding into the tube? And splitting the IAT wires off my 5 wire MAF?
I really like the Lingenfelter airbox, which fits tightly against all sides of the engine bay and hood. The K&N looks like it has major air gaps. The last time I was tuned, my IATs were 15-18 degrees over ambient at idle, and 1-3 degrees over ambient in motion. Keep in mind that these numbers were only achievable after I added aluminized thermal insulation to the bucket.
The LS3 MAF tube that I linked you to earlier has the bung already welded-on and includes a nice air straightener. If you have any questions, give the shop a call--they're good guys. You'll need an adapter from Casper to break out the IAT sensor (they also sell low thermal mass IAT sensors) and convert your harness to the LS3 slot-style MAF sensor connector.
There are a plethora of threads on LS1Tech that provide enough information to help your tuner recalibrate for the slightly different impedance of the LS3 sensor. This should go without saying, but wait to install the MAF until you get to the tuner. The difference in MAF diameter will reduce air flow velocity for a given condition.
While you're messing around with this stuff, this Spectre GM MAF 3-5/8" to 4" adapter might be useful to hold you over.
Even though I haven't modified the LS6 in my V, I used to have a 01 SS with "only" a LS1, and it got me 407rwhp and 368rwtq on a dynojet with cam only (232/240 .595/.609 112), LT headers, 25% ud pulley, lid, and tune. Stock heads(241), stock intake(LS6).
For the mods jclayc has, I agree those are sorry dyno numbers.
BS, those numbers are low, even for a LS6.
The most I've ever seen a LS6 make on a believable dyno is about 430 RWHP. I would be lucky to achieve 450 RWHP with my LS2 and ported heads with a FAST 102.
