408?
408?
Well, after being one of the people screwed by Kentucky Turbo for well over 20k, I'm finally getting all my parts assembled to finish my car. I have a fully forged 408 with all the good stuff. But, the problem is, that everyone keeps telling me I should have built a 370 or similar sized motor due to skirt clearances. So, I guess the question is, should I sell the 408 and build a 370-375 or keep the 408. 2900lbs, built T56.
Keep the 408 and match the proper turbo to it and it will do whatever you want it to do.
A GT5088, GT5288 and a GT5588 are all great choices for a 408 c.i. LS motor.
As 72camaro said, the right cam can bring the turbo online quickly at a low RPM and have it hold power to redline without tapering off.
Hey Josh! It's been awhile bud. I picked up LS9 heads, Tooley springs, pushrods, LS3 intake, possibly working on the LS3 Victor intake and a 4150 TB. I still have that K member for u, I got another. Upper and lower contol arms, and I'm seeing Madman next week to start my cage and rebuilding the front.
Martin, I'll definitely be getting a cam from you within the next couple of weeks. I'll have my engine builder call you this week. As far as turbos go, my buddy talked me into a BW S480 with .96
Art, I think the s480 is kind of small for a 408. I think Martin will agree. It will leave a lot to be desired. A better match would be a gt 5594, or even the gt91 like what is on my car. The 80mm compressor wheel can't compare to an 88, or 91 and up. The 5594 has a 94 compressor that will move a lot of air through that motor.
He's cutting that Crap of a cage that was put in, doing a chromemoly 8 point and setting up the front end for the intercooler and radiator. Welding in some subframes and not tubbing it ...yet :-)
Martin, I will be getting with you soon for a camshaft. I think thats the only thing thats left on my car. I think its a brutespeed blower cam and think that its not optimized to my setup. I will be getting with you soon for a custom grind to hopefully maximize my setup.
Nice Art, what all is he doing to it? I am going to be moving hopefully by the summer and have a bigger garage. I am going to fab a turbo kit for Sylvio's car and will have more room than my current setup.
We can attempt to offset the added airflow requirement with a smaller cam and cylinder head(intake runner and intake valve), but ultimately the easiest thing to do is utilize the right compressor wheel.
We can definitely optimize your set-up with a good turbo grind.
Is there a compressor map available for your turbocharger?
I would highly recommend purchasing the billet wheel S480 that Forced Induction offers if you stay with a S480 based turbo. The compressor map on a S480 IMO is not broad enough at lower pressure ratios(where your 408 will end up on the map) to move the airflow requirement your engine will demand efficiently.
Give me a call or shoot me an email(would be best so I can send you a spec sheet) and if we can we'll plot out some numbers and see where you're at with your current combination.
Agreed 100%. The turbo's you mentioned are also much more efficient in moving higher amounts of airflow at lower pressure ratios. A larger c.i. motor will not generate the manifold pressure a smaller motor will.
