ls swap harness. -24 tooth
Category: Engine - Electrical
Price: $250
Location (State): GA
Item Condition: Used
Engine: LS1/LS6
LS Engine?: Fits LS Engine
all the work is done for you. a painless harness that does the same job retails for $900.
i check Pm's on this sight once a day, but emails go to my cell. begoodchopshop@gmail.com
UPDATE: I have been receiving lots and lots of emails for this item and will answer them below. this harness is for a 411 PCM, Cable throttle body, and manual transmission.
provide it with (2) fused wires. and 2 non fused wires
-COnstant hot 12v
-ACC 12v (when the key is on)
-Ground
- signal to a fuel pump relay (if you want the ecu to turn the fuel pump on)
the harness has many lengths to choose from when it comes to measuring it. this one was mounted under the dashboard. if you locate a hole in the firewall behind the passenger side cylinder head you could mount it in the cabin. it is waterproof. so you can mount it in the engine bay if you keep the wires away from the headers.
a reply in an earlier PM. the pcm is not included.
okay thanks, I have no preference as of yet to where it will mount, just want options, and I have a pcm just need a harness....what was done for fuses on the set up?
all you need to do is provide the constant hot, hot acc(triggered by key), ground, and run a relay for the fuel pump. 4 wires all marked. the harness has all the other provisions for factory coils, sensors, yada yada yada.
Reply to a Email i already received: i will ship this anywhere in the us for 15 bucks,
i live in GA and travel a lot for work. so local pick up/ meet me at work ( usually any road race course in the south east) is OK.
if you want this harness be the first to paypal me with your address. if you're 2nd to paypal me i will refund your cash. i'm not a piece of ****, i just dress like one.
paypal address begoodchopshop@gmail.com
PM response: yes i do, and yes it will. if you have the already mentioned equipment.
still have it? i have a 2002 5.3 with ls1 intake and injectors 411 pcm... would this work?
reply to email 1.yes,
2.yes
i have no idea what that abbreviation stands for (sav)..
Interested in your harness..(1)will it work for ls1 also? (2) Could I come pic it up?? Are u in the sav. Area?? U can reach me by cell easiest.
2.yes
email reply: It does look kinda messed up but it does work the price reflects this. This powered flyin miata's targa newfoundland rally car. It had a 5.3 engine. All the plugins are there. everything you mentioned is there except for the oil pressure. the ecu doesn't have a oil pressure signal. The only thing you might have trouble is with is the throttle. if you have a 24 tooth crank signal (90% of 5.3's have the 24 tooth) then you can't use a factory ecu for drive by wire. the 350z chassis has a drive by wire from the factory. your only hope is to add in a cable operated throttle pedal (then this harness is what you need). or upgrade the motor (replace the crankshaft) with a 58 tooth reluctor. and run the newer PCM that comes on late model ls2, ls3.
short answer. this is the right harness for your engine.
this is the wrong harness for your chassis. One or the other will need to be modified.
Hello,
I have an L33 5.3 and t56 in a 350z and would like to know if this wiring harness will work with my engine? also the harness looks quite short in the pictures and a bit mangled near the pcm plug in. Are all of the wires in tact? non are broken? and are all of the plug in's there? injectors, MAF, throttle position sensor, knock, oil pressure, ect.
Thank you,
XXX
Thank you,
XXX
