2 wastegates and spring pressure
Took my car out today after adjusting my boost controller properly and Im running two 46mm precision wastegates. I had the red "6 psi" spring in it, and would only boost 3 psi with boost controller on the lowest setting. Turned the controller up to 70 and it went up to 10psi.. Is this normal? I just threw some 9 psi springs in it but it got wet out so couldnt test it yet.
