Complete LS turbo car part out!!!
Category: Drivetrain
Price: $1
Part Fits: 2010+ Camaro, 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V, 67-92 Chevrolet Camaro, 67-92 Pontiac Firebird
Location (State): MO
Item Condition: Used
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6
LS Engine?: Fits LS Engine
Log manifold set up uses factory manifold on left side crossover under the car to log manifold on right side
and turbo sits up front and has a flange for 60mm wastegate asking $500.00 OBO
Borg warner S475 turbo with upgraded t4 92mm exhaust wheel only 75 street miles will include the cold side outlet pipe and v band clamp with flange for 50mm BOV also will include 4" down pipe also has inlet fitting for oil line and drain back flange with 10AN fitting and hose. also will include a 90 degree hose for filter and a cone filter. paid $975.00 with out all the clamps and flanges and pipes Asking $975.00
a complete Holley HP Efi set up is set up right now for a ls2 but i can switch it back to a ls1 either way you would want it. it comes with all the regular sensors ( coolant temp, IAT, O2, ) but i also have a fuel pressure sensor a 3 bar MAP sensor and will also include a 24X crank sensor and 1X cam sensor and also a 58X crank sensor and 4X cam sensor. Paid $1,750.00 asking $1,600 with all the extra sensors
a set of 95lbs Precision injectors just had them cleaned and flowed 2 months ago will also incude a set of fuel rails with fitting. asking $375 OBO
Holley 12-1800 Fuel pump with pre and post filters and 12AN inlet fitting and 10AN Outlet and fitting to connect the filters to pump paid $600.00 without fittings asking $550.00 OBO
PTC 10" turbo converter was able to build 12LBS of boost on the brake great converter was built for 3800LBS car only 20 Street miles and one pass has LS1 crank snout and older style bolt holes will include SFI flex plate that was used on my car with this converter paid $500.00 plus $100.00 for flex plate.Can offer numbers so you can call PTC Tim is the one that spec this out great guys there. Asking $475.00
Turbo 350 trans that has had alot of work done to it all heavy duty clutches with pistons cut done to add clutches. HD sprag, Transbrake valvebody JW SFI bolt on bell housing, SFI trans blanket, B&M aluminum deep pan. This trans has been behind a 800HP BBC and will handle anything you can throw at it. asking $1,200.00 OBO will ship if needed on your dime.
78 Malibu Wagon roller has Weld draglite wheels new tires on front and 275 MT drag radials on rear 10 Point cage should certified to 8.50 bench seats with 5 point harness will need to be sent back to get re certified i have a ceritficate to get this done free. has moser built 9" with 3.50 gears and a spool 31 spline axles. G force trans cross member, drive shaft loop 3.5" DOM high HP driveshaft, Sumped gas tank, 6" lift off glasstek hood aftermarket guages and 5" tach you can call for more info asking $4,500.00 OBO also can send pics of anything you want.
please call or text me for quickest response 314-614-3990 i have pics of everything and i do accept Paypal with 3% to cover fees also will cover shipping on everything beside transmission if you buy @ my asking price.
