Thinking about Head/Cam...Suggestions please
Old 05-16-2004, 02:59 PM
Zo6Killer's Avatar
Default Thinking about Head/Cam...Suggestions please
Dollar for dollar, it looks like LS6 heads, springs, and cam would be the cheapest. Would it be worth it? What kind of gains could I expect from this proposed setup? I would like to get stage 1 or 2 LS6 heads, but the stockers are SO affordable, I almost can't resist.
So far, the mods are as follows-
All free mods
SLP lid
ACCEL Filter
SLP LM
Cutout in I-pipe
Fernco
Will probably get a 3200-3600 stall soon after H/C, and 3.73's as well.
Would I be beter off getting longtubes and ORY first, or would this H/C be worth it?
Thanks in advance!!!!!!
Old 05-16-2004, 03:09 PM
LS1TECH Sponsor
foff667's Avatar
you could get patriot S2 5.7 heads compatible with your 98 perimeter bolt setup you have now & a cam of your choice for like $1500 through tsp...I think that comes with PR's as well? Might be something to look into as stock ls6 heads wouldnt outflow the pp 5.7's
Old 05-16-2004, 03:22 PM
Zo6Killer's Avatar
I should also mention that one of the local engine builders (BRE) could do a "stage 1-street port" for fairly cheap. And yeah, the car has 112,000 miles on it now.
Old 05-16-2004, 03:35 PM
LS1TECH Sponsor
foff667's Avatar
great, what do they mean by cheap? What springs, what size valves & what will they flow when its done? Im assuming this isnt your DD, My patriot heads were in my hands in less than a week ready to go on, If they are doing your heads your talking the time it takes you to take them off, send them out and for them to do them to get them back on your car...just something to think about.
Old 05-16-2004, 03:48 PM
M6HuggerSS's Avatar
stock LS6 heads not worth it....get stage 2 5.3-5.7 heads.
and if you can do the LT headers when you do the H/C.
Old 05-16-2004, 07:02 PM
Suspended Sponsor Account
ForceFed HP's Avatar
we can set you up with a Stage1 set of heads with cam and push rods for $1695.00 plus shipping. also we will refund $250.00 of that if you return your stock heads to us, so final cost would be $1445.00. we are in the Louisville, KY area so are close to you also. a set of stock LS6 heads are not worth the cost IMO.
Old 05-18-2004, 03:34 PM
Zo6Killer's Avatar
Thanks for the info. Sounds like a good deal. With mods in sig. and longtubes/ory with the heads and cam, what do you think hp/performance would be, ballpark? And would a converter be NEEDED with that setup, or just a good idea?
Old 05-18-2004, 03:49 PM
LS1TECH Sponsor
foff667's Avatar
FWIW i made 373/339 w/ S2 patriots & 231/237 cam & 3500 stall vert in my similarly modded 98
Old 05-18-2004, 04:50 PM
WILWAXU's Avatar
Love my budget H/C setup!
MTI Stage 2E's and X1 cam
BTW.. get the converter first.
Old 05-18-2004, 04:55 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,222 Likes on 779 Posts
LS1Tech 10 Year
I would not install stock LS6 heads, I would go with something like ForceFed stage 1 heads.
Old 05-18-2004, 05:47 PM
Demon SS's Avatar
with our stage 1 heads on a 2000 Z28 we have a car making 393rwhp/385rwtq
mods are
LS6 intake
LT headers
Lid
exhaust(forget which one)
smallish cam (207/220 .573/.580 117.5 LSA) LPE GT2-3
3500 stall
running 7.46@93mph in the 1/8
so I would say with a similar setup you could get similar results, with a bigger cam should make even more power.
converter would be a good idea even without heads and cam
Old 05-18-2004, 06:05 PM
Scoobie's Avatar
Id talk to Forcefed for that price and your goals. Stock LS6 heads will underperform and run you around 900.00 used alone. JMO
Scoobs
