Help need advice on fuel system
Howdy, so I just replaced opti, and fuel pump and fuel filter. Used The treperformance fuel pump. I get everything back together check the fuel pressure. She's giving me 43 psi key forward car off. It slowly drops. I mean slowly like it should. I turn the car on. She runs smooth. No missfires or anything. I turn her off and call it a night. I come to start it this morning and it is running like crap. Stumbling, missing and stalling out. Put the f.p.g. on the schrader valve. She's putting out 10psi and dropping quickly? Please help fellas she's been sitting for 2 months.
Thanks
Thanks
Check from injectors all the way to tank for leaks, if nothing Pull the pump out and put a genuine Walbro in it... before you put it all back together verify pressure. Could be a bad check valve, crappie pump, leaking injectors, lline leaking. ..
