Twin BW s300's
Old 05-05-2014, 08:40 AM
boostin01's Avatar
Default Twin BW s300's
Would twin 66mm Borgwarner s300s (.88ar rears) be too big a stock 5.7lt alloy ls1? should i go smaller like say 60mm's? Car is approx 3000lb, th400 trans, 3.45 diffgears, occasional street driven. looking at ~14psi/1bar if engine holds up. if you need other info just ask. cheers.
Old 05-05-2014, 12:21 PM
Sarg's Avatar
Really just depends on what you want from the car.
Old 05-05-2014, 12:56 PM
Mel Carlson's Avatar
Yes. Do a single 76
Old 05-06-2014, 01:37 AM
boostin01's Avatar
Originally Posted by Mel Carlson
Yes. Do a single 76
next car will be something bw and single, this car is already setup for twins
Old 05-06-2014, 01:42 AM
boostin01's Avatar
for a drag car, nothing too serious though, just fun, with occasional street duties. so i suppose im after turbo that will provide killer midrange and half decent top end, but still not create a lag monster. A cam swap to something a little more boost friendly may be on the cards but prefer keep cost down and run std cam.
Old 05-06-2014, 05:39 AM
schmendog's Avatar
Im building a 347 with twin BW S359's right now, should be a great combo with .83 housings. I wanted to build the car for drag purposes and planned on S366 with a little bigger housings but I couldn't pass up the deal I got on these rebuilt turbos.
Old 05-06-2014, 07:17 AM
boostin01's Avatar
ahok, cool. Im keen to hear from people who are running similar sized BW's and what they think.
Old 05-06-2014, 01:58 PM
Forcefed86's Avatar
Sure it will work fine. Doesn't' seem budget friendly though. There are cheaper ways to blow up an engine. 14lbs is pretty wimpy. Twin 66's are overkill for that amount of boost. Typical LS1 (gen3) will be weaker than the newer 5.3/4.8's too.
I believe the fastest stock block 5.3 (gen4) record is held by a non-intercooled (E85) 5.3 with twin S366's. Pretty heavy chassis S10 as well...
I'd stuff some cheapy china t4 60-62mm deals on there for your goals.
Old 05-06-2014, 02:21 PM
Sales@Tick's Avatar
They won't be very efficient at 14psi on a 5.7 with stock heads, compression and camshaft.
Old 05-06-2014, 02:56 PM
mrstepheneades's Avatar
More like 25psi Martin? LOL
Old 05-06-2014, 04:06 PM
Lol wow... talking about a turbo here that's less than $600 brand new and somebody is going to tell you to buy cheap turds. jesus
Old 05-06-2014, 04:12 PM
stevieturbo's Avatar
A pair of 60mm's or thereabouts would make more sense, or some of the smaller S200 range.
AGP Turbo does some good offerings that would fit the bill.
Old 05-06-2014, 04:24 PM
BlwnLs1GTO's Avatar
Don't listen to too much of the BS on here.
That combo will work just fine for your Auto car. Sure there's plenty of other options out there that are more "efficient", but that combo will blow your engine up at 14psi just as good as anything else.
I would be more worried about your stock bottom end rather than turbo selection.
Old 05-06-2014, 04:33 PM
Forcefed86's Avatar
Where are you getting an S366 for less than $600? What I suggested makes much more sense for his application.(size wise). The brand name is irrelevant and would depend on the OP’s budget.
Though I must say some folks aren’t born with shiny silver spoons peeking out of their poop chutes… They may actually have to consider a more affordable overseas turbo option.
Old 05-06-2014, 04:39 PM
$600...almost. I'd sooner buy a reputable name like BW, even a budget unit than anything Chinese of unknown quality
http://www.ebay.com/itm/BorgWarner-Airwerks-S300SX3-66-S366-S300-88-A-R-Open-Scroll-Turbo-66-73-88-/121270703773?pt=Motors_Car_Truck_Parts_Accessories&hash=item1c3c4c169d&vxp=mtr
http://www.ebay.com/itm/Borg-Warner-Turbo-S300-S366-91-79-Extended-Tip-/220790099027?pt=Motors_Car_Truck_Parts_Accessories&hash=item33681d8c53&vxp=mtr
http://www.ebay.com/itm/Brand-New-BorgWarner-S300SX3-S366-T4-88A-R-Turbo-/130933995913?pt=Motors_Car_Truck_Parts_Accessories&hash=item1e7c463989&vxp=mtr
Old 05-06-2014, 07:59 PM
oscs's Avatar
6 months ago i would have agreed with the "dont buy china turbo" comment. Fact is those cheap little bastards are actually holding up in the real world. Would i buy a set? no, but im not really on a "budget"
Old 05-06-2014, 08:38 PM
Sarg's Avatar
A pair of S256 would be fun!
Old 05-06-2014, 09:35 PM
Paid 650 each for my s366's. 73 mm turbine and divided housing.
Old 05-06-2014, 10:44 PM
boostin01's Avatar
thanks for all the replys, youve all given me a bit to think about.
I should probably clear up a few things though, Im in australia which means cheap (junkyard) but strong short motors are difficult to come by unless from an actual importer. brand new bare iron blocks start at 1000 (us$) but a complete running alloy 5.7lt with 241 heads can be picked up for around 500-1000max. we have junkyard l98/ls2/ls3's over here but theyre similar price as a built motor so thats out of the question atm. So because budget is important im running the alloy 5.7 ls1, cheap and easy to source if anything goes wrong.
for a bit of a comparison between chinese and BW turbos, twin 70s from on3 performance will cost me around $870us for the pair, delivered to my door with in a few weeks, whereas the cheapest BW 66s ive found are around $1400 delivered and take upto 8 weeks to arrive
I suppose the answer for me would be to leave the BW 66's to those running decent psi and/or with a stronger engine, i stick to budget and i go a suitable sized chinese pair.
Old 05-07-2014, 06:45 AM
Forcefed86's Avatar
Huh thats weird the norm LSXS turbo distributors (like forcedinductions) sell them for 750+ shipping... The nice ones are over $1000 each.
I've heard about BW clones floating around ebay as well. I'd be nervous buying those. Still $1200 worth of turbo and additional plumbing/headache is overkill for 14lbs on a 5.7 IMO.
Quick Reply: Twin BW s300's
