11.80s possible?
11.80s possible?
going to the track for the first time this weekend really wanting to break into the 11s.
s10 that weighs 3000 with no driver, bored 5.3, carburated with dual plane intake, .598"/.596" 239/233 cam, double valve springs, titanium retainers, 241 heads, flat top pistons, brp 1 7/8 lt headers th400 with good shift kit, tci 4000 stall, 2 step, 8.8 rear end with posi and 3.73 gear, 90/10 drag shocks on front and 9 way adjustable shocks on the back, i also have 8.5x26 m/t slicks.
shift light comes on at 5700, rev at 6300. what should it be? timing at 32 degrees comes in a 2800 rpm. sound about right? I have a well knowledgeable guy going with me.
Do you have a dyno sheet? You will want to shift a few hundred RPM past where it makes peak HP. It's a balance of keeping it at the highest average HP. Ideally you wouldn't want to shift until power has fallen off to a lower point than where it will end up in the power band once the shift occurs.
Mine peaks at ~6300rpm but likes to be shifted around 6700rpm...might like more but that's as high as I want to spin it.
Old School Heavy
I figured with that short of a tire on the back and my 3.73 gear it will be like having a 4.10 gear and probably will go through the lights around 6400?
Old School Heavy
http://www.hotrodpitstop.com/tool.php#0
best run I got last night was a 8.06 (1/8 mile track). converting it to 1/4 mile time its a 12.65. truck was really rich all night. it needs a smaller carb and a 4.10 gear. i went through the lights last night in 2nd gear and only at about 6500 rpm lol.
well i made it in the 11s.... kinda.. 7.62, 11.96 converting it to 1/4. im thinking the mph and 60ft it kind of slow.
1.715 60f
4.894 330ft
7.62 660ft @ 89.82 mph
1.715 60f
4.894 330ft
