01 Trans Am going back stock. TT2s,Monster triple clutch,P1SC,cam,crankshaft,CBR
Category: Engine - Power Adders
Price: $123456
Part Fits: 2010+ Camaro, 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V
Location (State): TN
Item Condition: Used
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6
LS Engine?: Fits LS Engine
Here's the short list:
•Autometer #3376 Electric 2bar Vac/Boost gauge with peak recall. Used $100 SHIPPED
DETAILS:
•P1SC-1 kit for 98-02 Fbody, Camaro, Trans Am.
Head unit made in 2010. I have put about 500 miles on this kit in the last year. No bearing noise. Max boost I ran was 8 lbs. It saw 10 lbs one time. Includes head unit, one bottle of Procharger oil, "open" red race bypass, vacuum block with all the rubber hose necessary, larger K&N air filter and complete hat assembly, Procharger bypass ports are blocked off, 3.5" intercoolers and all intercooler piping and clamps, 2 piece fan shroud with Procharger fan, Radiator hold-down, fender well panels, 9" spal fan(new in box, will sell separately), Procharger 8 rib crank pulley, two 8 rib belts, multiple 8 rib head unit pulleys. It's missing: the J-bracket assembly($400), and 6 rib crank pulley($175). Then you'll need spark plugs and fuel system. The cruise/AIR bracket isn't included, but isn't absolutely necessary. Most of this kit was bought brand new a year ago by me (500 miles ago). Only the head unit, fan and shroud, and a few pieces of the IC piping have unknown mileage dating back to 2010. ***SOLD***
•17" TT2s Polished aluminum wheels. Front are 17x9.5 with 7" backspacing and rear are 17x11 with 7.75" backspacing. Bolt pattern is 5x4.75.
Nitto 555 275/40 frt and 315/35 ET street 11" wide rear. Paid $1800 for this setup and drove on it for about 50 miles. No damage. Local pickup only. Must come to me. I will not leave the city. ***SOLD***
SOLD items:
•Fbody 17" Aluminum TT2 wheels and tires complete set. 11" wide rear. Used 50 miles $800 SOLD
•P1SC kit 98-02 Fbody. Used 500 miles by me. $3300 SOLD
•LS1 crank, gun drilled, short flange for ls1, new $150SOLD
•Monster triple disc stage 1 clutch. New $1400 SOLD
•CBR 8.65" crank pulley for use with Procharger. Used $200 SOLD
•Dynotune fuel pressure gauge. New $75 SOLD
•Aeroforce Interceptor Scan Gauge for 2005 and older. Used $100 SOLD
•DevilsOwn methanol kit with Alkycontrol tank and level sensor. Partially installed but never ran. #10 and 12 nozzles $350 SOLD
•SD 60 lb injectors. Used 500 miles $200 SOLD
•Lonnie's dual in-tank fuel pump setup with bucket and hotwire kit/wiring harness. Used 500 miles $400 SOLD
•LS6 block used, new cam bearings, surface rust in sleeves $150 SOLD
•Autometer #3301 mechanical Vac/Boost gauge. Used $50 SOLD
•Autometer 93-02 A pillar triple gauge pod without gauges. Used $40 SOLD
I am trying my best to keep up with everyone's messages. If I don't respond then feel free to check again with me. Thanks!!
^^edit: 10 more pics added
Aster setup has been sold and I can't find my dang factory harmonic balancer. Someone got a factory 01 fbody harmonic balancer they want to sell me??
Oh and I changed the price of the kit.
