1999 LS1 camaro remote door locks
Old 05-16-2014, 08:45 PM
pappy77's Avatar
Default 1999 LS1 camaro remote door locks
NEED HELP!! New Here so here's my question. My door locks actuate whenever they want. I disconnected both switches from both door panels and they still try to unlock. I also disconnected both plugs on drivers door connections and it stopped but the passenger door was still actuating and there is no key in the ignition. I have gremlins.
Has anyone run into this and where else should I look. I'm hoping it's not the body control module. Thanks in advance. Pappy
Come on someone must know something?
Old 05-17-2014, 01:19 PM
NL_SLI_GT's Avatar
Perhaps youre remote/fob is faulty and keeps sending signals. You could try reprogramming it.
Old 05-17-2014, 03:54 PM
pappy77's Avatar
I didn't even have the remote even around the car it was miles away. I only had the keys. That's why I'm stumped on that one. Anything else? Thanks alot for replying.
Old 05-18-2014, 09:13 AM
dreww's Avatar
is there and aftermarket security alarm/system?
are you blowing fuses for door locks? are your windows affected?
Old 05-18-2014, 11:27 AM
pappy77's Avatar
No none of those things. Everything there is good. I was wondering if there is a relay attached to the BCM or anywhere else that could cause it? I'm telling you it's just weird. Thanks for the reply. This is a stumper.
Old 05-18-2014, 07:44 PM
unforgiven's Avatar
Could be wiring in the conduit between the door and the body. Driver's side is most likely since it get opened and closed the most.
Old 05-19-2014, 08:37 AM
pappy77's Avatar
Thanks unforgiven. I checked all in the door and through the body panel and all was good there. No shorts or broken wires. Everything was good.
Old 05-19-2014, 09:05 AM
NL_SLI_GT's Avatar
Does this clear anything up,
and
And maybe this thread
Old 05-20-2014, 01:57 PM
pappy77's Avatar
Thanks NL_SLI_GT Must have taken awhile to find this. I appreciate it and will go through it and see what I find and keep you posted. Thanks again Pappy.
Old 05-21-2014, 05:30 PM
Infantrymarine's Avatar
Have you tried to disconnect the actual harness that plugs directly into the door lock actuators? That will remove ALL power going to the actuator itself. If, it stops after doing that, then replace your door lock actuators. LMK what you find.
Old 05-21-2014, 08:43 PM
pappy77's Avatar
Thanks I had disconnected both switches on the doors and it was still doing it. i disconnected the the drivers door actuator and it stopped but the passenger door kept doing it.
Quick Reply: 1999 LS1 camaro remote door locks
