1999 LS1 camaro remote door locks
NEED HELP!! New Here so here's my question. My door locks actuate whenever they want. I disconnected both switches from both door panels and they still try to unlock. I also disconnected both plugs on drivers door connections and it stopped but the passenger door was still actuating and there is no key in the ignition. I have gremlins.
Has anyone run into this and where else should I look. I'm hoping it's not the body control module. Thanks in advance. Pappy
Come on someone must know something?
No none of those things. Everything there is good. I was wondering if there is a relay attached to the BCM or anywhere else that could cause it? I'm telling you it's just weird. Thanks for the reply. This is a stumper.
Have you tried to disconnect the actual harness that plugs directly into the door lock actuators? That will remove ALL power going to the actuator itself. If, it stops after doing that, then replace your door lock actuators. LMK what you find.
Thanks I had disconnected both switches on the doors and it was still doing it. i disconnected the the drivers door actuator and it stopped but the passenger door kept doing it.
