alternator issue!!
Old 05-18-2014, 11:48 PM
5.slow99's Avatar
Default alternator issue!!
Has anyone seen a alternator pass a bench test and in fact be bad? i moved the alternator from the bottom left to the top right and extended the pigtail. since then i start the car and the car doesnt charge. checked power and voltage and everything is okay. any advice???
Old 05-19-2014, 08:51 AM
Save the manuals!
wssix99's Avatar
Yes, but you should check your exciter wire first - especially since you extended it.
Old 05-21-2014, 03:17 AM
98boxer's Avatar
On an older car i had, the auto parts store tested the alternator and it read good, but car was turning off. Finally had them check it while the car was running, all was good again. Again i had them retest it but this time with the headlights on, and bingo, alternator showed it wasnt charging enough when headlights were on.
Old 05-21-2014, 06:18 PM
xenergyx's Avatar
What type of butt connectors did you use at the extension?
Old 05-21-2014, 11:16 PM
Save the manuals!
wssix99's Avatar
^ you said butt...
... sorry. Great question. A high likelihood the problem is there.
Old 05-22-2014, 10:04 AM
xenergyx's Avatar
if you used the pull apart ones thats bad and mess's with connectivity.....use the more permanent ones either blue or red thats crimpable on either side
Old 05-23-2014, 09:08 AM
Save the manuals!
wssix99's Avatar
A lot of people also disassemble the connector and put the wire in the wrong slot when putting it back together.
Old 05-23-2014, 10:54 PM
dailydriver's Avatar
The heat shrink versions are also a good idea.
Old 05-24-2014, 04:53 PM
xenergyx's Avatar
I think not sure this might be on all 2000 and newer TA but if you access the bundle and follow the pigtail wire the wire will be covered by heat shrink cut into it and use the red butt connector after that solder point ....the wire they used for the agitator just seems .......brittile only like 5 or 6 strands in it :/
This may be just on my car too from previous owner breaking off pig tail during removal
Quick Reply: alternator issue!!
