Transmission fluid line nick
I finished my cam install and started the car up and transmission fluid flew everywhere. I inspected the line near the balancer i have a small nick on one of the transmission lines. How would i go about fixing this line without having to replace it? Thank you.
You can cut a section of the line out and replace it with rubber transmission cooler line and double hose clamp it on both sides. In a perfect world you would slightly flare each side of the lines to help prevent leaks. The trans cooler lines do not see that much pressure.
Make sure you use transmission cooler rubber hose though, regular rubber hose won't hold up.
