Odd 150 shot problem.
Old 06-01-2014, 07:58 PM
enzo354's Avatar
Default Odd 150 shot problem.
I'm at an odd stage with my 150 shot. My system is
NOS Sniper bottle
all -4an line
Brand new BRAND X solenoids
Harris Speed works plate
Engine is a 5.3, th400, 4000 stall with anti balloon plate, BR7EF's gapped at .035
Now, my fuel pressure is a bit on the high side thanks to the Corvette regulator, about 65-70ish at idle. Now here is the issue
On a 100 shot, I jetted it at 52- 31 (I know it calls for 27, but I didn't have one around there so I tried it out.) It pulled perfect, and it was just a bit rich but it had no issues. I had about 4 degrees of timing pulled.
I bumped it up to a 150 shot, 62- 35 jets. I would spray in 2nd. My AFR is about 11.3 NA and then on spray it was reading low 9s, and it was bogging a bit. I started down sizing the fuel jet, and I ended up getting to a 20 before it managed to register on my wideband and show some low 10's for an AFR. I was pulling a bit more timing than I should be, 8 instead of 6 just to be safe. But what could be the issue here? I have a full warm bottle with 1000+ psi when I spray.
So my question is, why might I need to be leaning out the fuel side so much more, could something be sticking or plugged? I'm getting plenty of nitrous pressure at the purge and it seems like it's pulling great with the 150 shot.
Old 06-01-2014, 08:05 PM
enzo354's Avatar
The 62-20 file is spraying just in 2nd
the 62-20 file is spraying in 2nd and 3rd
File Type: hpl
File Type: hpl
Old 06-02-2014, 09:10 AM
Ls1tech & Truck Sponsor
NitrousExpress's Avatar
4 jet sizes can make a considerable difference. For the 150 shot, what jetting is recommended there?
-Garrett
Old 06-02-2014, 12:24 PM
enzo354's Avatar
The recommended is 62-35, and I'm at 62-20. I looked over the nitrous side, and my line going to the bottle looks like it was smashed at one point. I think I might have found my problem.
Old 06-02-2014, 03:06 PM
A kink in the line will cause a problem. Glad you found that!
-Garrett
Old 06-03-2014, 12:04 AM
enzo354's Avatar
Thanks for the help! I'm sporting NX logos on all of my visible set up parts by the way haha
Old 06-03-2014, 08:45 AM
Haha, cool. Let me know if you need anything else!
-Garrett
Quick Reply: Odd 150 shot problem.
