Alignment: 2 or 4 wheel?
Old 06-04-2014, 10:59 AM
wayland1985's Avatar
Default Alignment: 2 or 4 wheel?
Hey all, just needed to ask real quick before I make an appointment.
I just put Koni yellows on my 2001 SS... I opted for the lower perch, and did the hose mod.
Does the car only take a front end alignment? Or are there adjustments in the rear as well?
Thanks!
Old 06-04-2014, 11:13 AM
Cpt.Derrek's Avatar
Thanks!
adjustments are only for the front unless you have adjustable lower control arms or adjustable panhard bar
Old 06-04-2014, 11:22 AM
SoFla01SSLookinstok's Avatar
Well, as alignment goes, yes only the front wheels. You have a solid rear axle so no wheel alignment is needed in the rear. Having adj. aftermarket items linked to your rear is for adjusting the placement/angle of the rear end.
Old 06-04-2014, 11:38 AM
Moderator
jimmyblue's Avatar
If a shop tries to sell you a 4-wheel alignment on
your solid axle domestic vehicle, leave.
Old 06-04-2014, 12:10 PM
It's not mine! woo hoo!
demonspeed's Avatar
As mentioned above, unless one has adjustable lower control arms and panhard bar in the rear, then a front end alignment is all that can be done. With that said, the rear thrust angle should be checked when doing even a front end alignment on a solid rear axle.
Old 06-04-2014, 01:06 PM
Thanks for the help guys. I just wants to be certain that I wasn't sold something I don't need
Quick Reply: Alignment: 2 or 4 wheel?
