Budget injectors for E85 with hp tuners?
Old 06-25-2014, 06:14 PM
adrynalinjunkie's Avatar
Default Budget injectors for E85 with hp tuners?
After buying all the JGS gates and BOV I am too low on cash to buy the dominator ECU until next year....so what are some good cheap injectors to look for in the classifieds that are 80s or bigger that I can run with HP tuners on E85?
(Yes I realize they will max out around 750 whp)
I am just bored to death with 410 whp n/a...lol
Old 06-25-2014, 06:22 PM
Iam Broke's Avatar
FIC95's here. I don't know what engine/manifold you have or I'd recommend the ID1000's. They only come in the taller LS1 style though and the ID1300 price is re-dick-o lus.
Running ~650 whp on E85 @ 10 psi PD.
Had to scale my tune 80% to get them dialed in on a '12 LS3/E38.
Old 06-25-2014, 07:14 PM
oscs's Avatar
racetronix make an in expensive injector. I don't know how they hold up to E85 though
Old 06-25-2014, 07:20 PM
I went on FIC.com and I couldn't find those in the LS1/6 section..
I guess I will call them tomorrow.
What about those 80#deka's?
BTW I have the Holley Hi Ram intake with EV1 plugs on my harness.
Old 06-25-2014, 07:58 PM
Iam Broke's Avatar
Hard to get good data for the DEKA's afaik.
Here's the FIC 95's at 3 bar. 103 @ 4 bar (58 psi)
http://fuelinjectorconnection.com/sh...p?productid=21
Old 06-26-2014, 12:14 AM
skinnies's Avatar
80lb siemen dekas are good to around 950rwhp on e85 with enough pressure behind them, I've been 159mph at 3340lbs with them.
Old 06-26-2014, 06:43 AM
Old Geezer's Avatar
This??
http://siemensdeka.com/specsheets/FI114992.jpg
Old 06-26-2014, 07:21 AM
LS1 240sx's Avatar
I went with Lucas 120lb injectors and a AEM P&H driver, pushed 19psi out of a on3 76 on E85 and my duty cycle was around the low 70% range at 58psi base fuel pressure.
Old 06-26-2014, 08:05 AM
Ryans99ls1's Avatar
Ran siemens 80lb'rs for 2 years hassle free. Super easy to tune and will more than satisfy for the time being. Less than $400 and are direct swaps. You can unload them easily when you are ready for more.
Old 06-26-2014, 08:11 AM
Blackpanther99's Avatar
Dekas 80s will do.
Old 06-26-2014, 09:56 AM
7 Second Club
NicD's Avatar
SD 80s will work but they are dirty in the lower pulsewidths. The FIC 95s are a lot better down low and obviously have more head room.
Quick Reply: Budget injectors for E85 with hp tuners?
