Harmonic balancer for Fbody
Hello guys,
I have an issue with my new built engine. Turns out when I took my original Balancer out it did not have a key way. This built engine the forged crank does have a key way. Do you guys know of any balancer made for the fobdy accessories and has a key way.
Has anybody else run into this issue?
Thanks,
Thanks,
how come ati uses a sticker instead of laser etching the info onto the surface? and would a 2 keyway damber be ideal on a supercharged engine making 800 or so hp?
dont know where you got that info...
my ATI balancer timing marks are etched...
the front has a sticker...but not the timing marks.
and a double keyway, or a keyway and a secondary pin is always a good choice when you want to make power.
the ATI balancer comes with a single keyway, but you can order it with a 2nd keyway cut into it as well.
