Fs/ft 91 ls Turbo Mustang
Year: 1991
Make: Ford
Model: Mustang
Price: $14500
Mileage: 1111111111
Private or Dealer Listing: Private Listing
Location (State): TN
Color: Green
Transmission: Automatic
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
1st off this car is a street car that you can drive just about anywhere. I do a lot of cruising in the car. The guy who had it before me street raced it and hurt a lot of feelings.
Original calypso 5.0 car with black interior, the car has a ls 5.3 with a precision 76 mm turbo on 17psi and e85 and would drive it anywhere, I bought this car a while back with a bad transmission. I put a TH350 in it. And a MSD 2-step. The car went 6.34@111 with a 1.54 60ft. Just like everyone else I wanted to go faster so I bought a TH400 with a brake put it in and 1st pass on the brake I slung the driveshaft on the big end and destroyed the trans and driveshaft. Then I had PTC to build me a new TH400 with a brake, I had Wiles driveshaft's in Jackson Tn to build me a race driveshaft, bought a new set of drag radials and pulled the 3.08 gears and put 3.55's in it. Now I've taken it to the track twice and I can't hook it so I'm burnt out. The car needs a anti roll bar and a roll cage but I'm done. I want something different. The only thing i can think it really needs is the arm rest on the door panels, I do have some gray ones but the driver side is rough. I'm asking $14,500 and I will consider trades that are worth $14,500. I don't want anything else to race unless it's something cheap and i get quite a bit of cash in top.
I really want a turbo reg cab silverado also will consider a fast reg can silverado mom turbo and cash
I'd like to have a nice patina rod/shop truck,
nice 900 or 1000 RZR, will trade for a. 800 RZR with cash my way.
67-69 Camaro
C5 or c6 vette
but will look at all trades that are reasonable. it has rear seat delete also, and heres a list off the of mods…..
MOTOR:
2006 5.3
LS6 intake
Head studs
PAC valve springs
TRANS:
New PTC TH400 with Trans brake.
YANK 3400 converter
SFI flywheel
hurst quarter stick
New Wiles Race Driveshaft.
I drive the car a lot and drive it up to 40 miles one way if that tells u anything, lol
REAR:
8.8 moser 28 spline axles
POSI unit but not sure the brand
full 5 lug conversion
3.55 Gears.
SUSPENSION:
AJE LSX k member
Lakewood 90/10 struts and 50/50 shocks
aftermarket upper and lower control arms
sub frame connectors
FUEL:
holley dominator fuel pumps
holley adj regulator
80lb injectors
holley fuel rails
sock gas tank with sump
E85 setup
Wheels and tires:
Greg weld 5 star with 275 MT dr like new condition
New front tires with less than 20 miles on them.
Turbo:
precision 7675
A2A innercooler
Located in Ramer, Tn. Between Selmer , Tn and Corinth, ms. WILL NOT TRAVEL.
CALL OR TEXT 731-616-6022
