Pace Setter L/T 98 Z-28
Old 08-02-2014, 07:35 PM
98MysticGreen's Avatar
Question Pace Setter L/T 98 Z-28
Anyone on here have or use to have Pace setter long tubes on 98-02 camaro or trans am and experience the y-pipe hitting the floor board of vehicle. I had to dent the y-pipe that connects to the header to minimize the noise and it helped out but not quite. I think where the y-pipe connects into the exhaust is hitting as well
Has anyone experienced this and if so what did you do to correct it.
Please keep advice positive thank you
Old 08-02-2014, 07:38 PM
98CayenneT/A's Avatar
You need poly motor mounts would be my guess
Old 08-02-2014, 07:50 PM
The car is lowered not sure exact drop and has kyb adjustable shocks.
Old 08-02-2014, 07:53 PM
I'm guessing your motor mounts are shot is what I'm saying
Old 08-02-2014, 07:59 PM
actually No the motor mounts are fine. Car only has 80 k on it. I had the transmission rebuilt 2 months ago at a shop and was told I didn't need to replace them; I was warned before the work was done that i might since the car is 16 years old. But by my surprise I was told they were fine.
Old 08-02-2014, 08:03 PM
After Lt and ory exhaust would bang my floor, 55,000 mi on car, replaced motor mounts with poly, problem solved. My stock ones were not terrible either
Old 08-02-2014, 08:08 PM
Ill have to hit up my shop and ask about swapping them out.
But I wanted to see if anyone on here had or has the same issue I do with PACE SETTER .... I know Kook's are much better header but also $400 more as well. Ive heard they are better because they stretch longer then pace setter so therefor when the y-pipe connects to header / exh it sits lower and not right up against the floor board.
Old 08-04-2014, 04:34 PM
bump !
Old 08-25-2014, 12:40 PM
Super Speed's Avatar
It's a common problem with headers.... Have you tried a search?
Old 08-25-2014, 12:41 PM
https://ls1tech.com/forums/generatio...-ratlling.html
https://ls1tech.com/forums/generatio...ed-advice.html
https://ls1tech.com/forums/generatio...s-banging.html
https://ls1tech.com/forums/generatio...oorboards.html
ETC ETC ETC
Originally Posted by TechCam97
No offense man, but you didn't really search that hard.....
X2
Old 08-25-2014, 12:43 PM
/thread
Old 08-25-2014, 12:44 PM
"MAC"'s Avatar
I have an x pipe connecting to my LT PACE SETTERS idk if that fixes the issue but as far as i know its not hitting my floor board hope it helps.
Old 08-25-2014, 12:47 PM
The issue is mostly attributed to the Y-Pipe!
OP: Go by the autoparts store and pick up a high temp radiator hose and a band clamp. Cut the hose flat and then clamp the hose in the spots that the YPipe is banging. This will take care of the noise.
A more "permanent" solution involves replacing your mounts as stated in the other threads....
Old 09-18-2014, 02:44 AM
Wrong section btw...
Old 09-18-2014, 02:54 AM
Super Hulk Smash
JakeFusion's Avatar
Moved to the correct section.
Poly motor mounts would be my preferred solution.
Old 09-18-2014, 11:30 AM
Cstone812's Avatar
It's a common issue that you should have searched for. You need poly motor mounts. Any exhaust you put on the car will probably hit the floorboard.
Old 09-18-2014, 01:49 PM
Fry_'s Avatar
I think the biggest mistake was buying Pacesetter's to start with. You can buy stainless steel headers from Speed Engineering cheaper than you can buy painted Pacesetters. This is why you do a search before buying anything.
Old 09-18-2014, 01:51 PM
Cstone812's Avatar
Agreed. Much better headers out than pacesetter nowadays.
Quick Reply: Pace Setter L/T 98 Z-28
