BiGcamo here....'Merica!
Hello Fellas
I am a noob to this board, and just recently purchased my first F body LS1. I am looking forward to reading as much as I can.
Question? Is reputation here earned or does it go by who has the longest mullet??? If its the longest mullet, I guess I better start to let my hair grow!
'Merica!
2001 Camaro SS
'Merica!
2001 Camaro SS
2001 Camaro SS M6
93 tune
SLP intake/lid
UDP
Pacesetter LT
SS Magnaflow
3.90 gears in stock 10 bolt for now
Koni Adj Shocks
UMI torque arm, adj. panhard, LCAs, subframe connectors, strut tower brace, sway bars etc.
Poly bushings on motor/trans
drilled/slotted rotors with Hawk HPS pads, SS lines
275's in front, and 315's in the rear. Sumitomo for now until I burn them off!
93 tune
SLP intake/lid
UDP
Pacesetter LT
SS Magnaflow
Koni Adj Shocks
There is a drag strip 5 miles from my house so I have no excuse! Plus, because of the strip there are a lot of places with dynos available.
My plan is to go to a test and tune night to see where I am at in the 1/4 mile. Then start to make some decisions from there. I want to drag my car, but I love playing on the streets too so went with the M6.
I'm thinking of going with a Ford 9'' rear end with 4.10s or more.....but I don't know if I can resist camming it first. I can't do everything at once. Eventually, it will have a built rear end, cam, valve spring upgrade, Fast Intake etc. Hopefully some new heads too.
My goals are to make it as fast as financially possible at the track NA then go from there. The motor has been well taken care of up until this point, so I don't want to blow it up TOO quick.
If you guys have any ideas or advice please do not hesitate to tell me.
Well nest thing to do is build suspension, then rear, trans and then the engine. That way you take care of the weak links first. Also tires you can go as wide as 10.5 safely maybe 11" wide. As always post up pics and slips and a vid when you race. Best of luck on your build and racing.
[QUOTE=BiGcamo;18371678].
Cam is the most "fun" upgrade. Rear is best insurance for M6
I kind of did it backwards in most's opinion (see sig). I did tranny first, then suspension, then cam, head, nitrous, etc. Now I'm sitting on a time bomb @ 532rwhp with 10 bolt Rear WILL be next.
[QUOTE=ragtopz28;18371992]Thanks! Good luck with that 500hp 10 bolt!
