I take the key out, CAR WON'T SHUT DOWN!!!
Old 05-21-2004, 09:55 PM
yyz28's Avatar
Thumbs down I take the key out, CAR WON'T SHUT DOWN!!!
Ugh... Well, this is interesting.
So, I have the car detailed today, drive it back to the office, turn the key to the OFF position, pull it out...
AND THE @#$\ING MOTOR IS STILL RUNNING!!!!
...no, I'm not kidding.
So I play with it a little. Volt Meter drops when the key is removed, so it appears to be shutting down power from the Alternator and going to the battery. I can't put it in gear with the key out, AC does not work, so it's like everything EXCEPT the piece that tells the computer it can stop now is working as expected.
...It's also doing it only after driving it for a while. I can turn it on and right back off if it's cold.
I got it shut down by pulling the fuel pump fuse, and once the engine stops, the rest of the system does die, and the car is totally shut down. I'm HOPING the detailers got some water where it shouldn't be, and it'll dry out... it's TOO coincidental that this happend after I had it detailed today.
...anyone else ever heard of this? Any ideas? Help.
Almost forgot, it's a 2000 Z28.
Old 05-21-2004, 09:59 PM
Dope's Avatar
That's uhhh..wacked. I assume we're not talking about dieseling, we're talking about normal smooth idle and all right?
Dope
Old 05-21-2004, 10:01 PM
Senior Member
Country Boy's Avatar
Dope
Our cars wouldnt do that since the timing is computer controlled.
yyz28's Avatar
Yeah.. Not diesling... it's like... Running GREAT! If I could get it in gear, I could go run the quarter.
I'm telling you, this is REALLY F-ed up.
Old 05-21-2004, 10:04 PM
Dope's Avatar
Yes but obviously the computer isn't turning off like it should.
I seriously have no idea. Let the car sit and dry out overnight and see how it is tomorrow?
Dope
Old 05-21-2004, 10:10 PM
Senior Member
I would..... actually, I dont know. Maybe take the harness off the computer and see if its wet/ dry it out??
Old 05-22-2004, 04:50 PM
Ferocity02's Avatar
Thats odd... I agree, set-up a fan in your engine bay and maybe take out some connections and blow them out. And if it happens again, I think a better idea would be to just stall the motor. Safer maybe, something about stopping the fuel pump while its running doesn't seem like a hot idea, maybe it's just me.
Old 05-24-2004, 11:33 AM
OWENMUSTANG's Avatar
doubt this will help..
i had the same problem with 1 of my stangs. turned out to be a bad ground
in the cluster..
Old 05-24-2004, 02:14 PM
yyz28's Avatar
Thanks for all the input guys... It turned out to be my fan switch. They had flipped it on when detailing the car, and I hadn't noticed it. It only happened when hot... Somehow, the fans coming on during normal operation created a situation with the Fan switch that made the PCM think it shouldn't shut down. I'm workin' great now! Thanks!
Old 05-24-2004, 02:38 PM
Motorboater
SilverGhost's Avatar
yeah my buddie's car did that last year.
turned out to be one of the grounds that connects to the frame up next to the radiator shroud wasnt down all the way tight and was causing it to happen
