spudering engine sound, firebird 2001
Old 09-01-2014, 02:43 PM
unreal1171's Avatar
Default spudering engine sound, firebird 2001
More recently the engine has been making a spudering sound when the gas is pressed. The more it is pressed the louder it gets. It seems to have less power and I can only assume it could be a blown head gasket, a miss-firing spark plug, or maybe a lifter. But based on how I described it is their anyway to figure this out without going to a mechanic to rip it all apart?
Old 09-01-2014, 03:39 PM
LS6427's Avatar
I assume you have NO SES light or codes in the PCM....? You should go get a code scan even if you see no SES light on.
I personally think you have a failing 02 sensor(s)........your symptoms are exactly that.
Does the hesitation clear up if you hit the pedal down harder and try to accelerate...?
Old 09-01-2014, 05:18 PM
unreal1171's Avatar
P0420
P0420 - Catalyst System Efficiency Below Threshold Bank 1
P0128
P0128 - Coolant Thermostat Malfunction
Yes the ses light is on and has always been on since I got the car pretty much, abs and low oil light, but i think the low oil light is going on because the gauge isnt working and not moving, but plenty of oil.
Old 09-01-2014, 07:02 PM
LS6427's Avatar
Originally Posted by unreal1171
P0420
P0128
Is your car a 1998...?
Could just need a new coolant temp sensor....
Is your temp gauge working normally..?
Old 09-02-2014, 10:55 AM
unreal1171's Avatar
its a 2001 v6, temp gauge works, just oil level one doesnt seem to move
Quick Reply: spudering engine sound, firebird 2001
